    Oct 2007
    Can two files (movies) be burnt to one single DL disc using ImgBuurn ?
  2. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Sure if they are authored together.
    Or you can burn them onto it in separate folders but you won't be able to watch both of them on a standalone player.
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Depends.
    If you are just copying AVI/DivX files to a disc as data, yes. If you have DVD VIDEO_TS folders, no.
    In the latter case, look up the reauthoring tools and guides here.
