  1. I'm having some difficulties with playing a VCD I recently made . It's my first one, so I followed the turorial word for word. After the tedious converting process, I went ahead and burned the VCD. When I went to put it into my DVD player (a Samsung that says right on the case that it supports VCDs), it said "no disk." Anyone have an idea what I am doing wrong? I'd hate for all that time to have gone to waste .
  2. What is your Samsung's model number?
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  3. It's a DVD-M101.
    Feb 2001
    Palmdale, CA
    according to the reports found here on the site your player does not support cdr's only cdrw's, you may want to reburn on a cdrw and re try it. Samsung players can be very, very finicky about the media so I would try a couple fifferent brands of cdrw's and cdr's, you might find one that would work, also read the user reviews here, they might have a few sugestions.
