hello guys
i am looking for any tool can convert srt to xml , please if you
know one tell me ,
thanks
.SRT to .XML
Are you sure of that???
P.S.: Homework done.
According to Weakipaedia, there are
three XML-based subtitle formats: USF, SSF, and TTXT. If this latter is
what you meant by "XML", then MP4Box might give you what you want:
{ source: http://gpac.sourceforge.net/doc_ttxt.php }Find an SRT or SUB subtitle file, and run MP4Box -ttxt file.srt. This will convert the subtitles in TTXT format.
HTH!
will , that not work
I know this site can convert from srt to xml
http://www.as-flash.com/components/#comment-3
but i want Desktop tools for that not a site , -
Could you please tell us what player accepts that "raw" kind of .XML
as a valid subtitle file?
[ EDIT ]Code:<title id="9"> <time start="00:01:36,343" end="00:01:38,675"/> <text1>Get some sleep, Frodo.</text1> </title> <title id="10"> <time start="00:01:48,956" end="00:01:53,052"/> <text1>The power of Isengard</text1> <text2>is at your command...</text2> </title> <title id="11"> <time start="00:01:53,260" end="00:01:57,663"/> <text1>... Sauron, Lord of the Earth.</text1> </title> <title id="12"> <time start="00:02:01,001" end="00:02:06,803"/> <text1>Build me an army worthy of Mordor.</text1> </title> <title id="13"> <time start="00:02:12,379" end="00:02:16,839"/> <text1>What orders from Mordor, my lord?</text1> <text2>What does the Eye command?</text2> </title> <title id="14"> <time start="00:02:17,318" end="00:02:19,218"/> <text1>We have work to do.</text1> </title>
OK, a quick query "srt to xml" @ Google reveals that the "raw" XML subtitles
are used by some FLV players, and so far only PHP scripts are able to convert
srt to xml.
Convert XML to SRT subtitle file
By subsync in forum SubtitleReplies: 7Last Post: 15th Jun 2015, 18:08 -
CLI to XML
By eon_designs in forum Video ConversionReplies: 1Last Post: 29th Apr 2010, 11:50 -
Xml tags when adding srt subs to mkv with mkvmerge gui?
By branch in forum SubtitleReplies: 0Last Post: 15th Mar 2010, 00:11 -
Subtitles Tools (SUB to SRT 1.33) for OCR Chinese Txt to SRT
By dennis3377 in forum SubtitleReplies: 0Last Post: 10th Dec 2009, 01:46 -
Any best tools to join 2 srt file rather that Time Adjuster?
By aris in forum SubtitleReplies: 1Last Post: 12th Dec 2008, 22:17
