Some help please. I have already installed Driver Genius Pro (trying it out) to find updates for my drivers. Before i pay for this software to allow me to install my updated drivers , I want to know if there is a better program out there. I want to reformat my PC. I have Windows Vista 64 Ultimate. Question is, is there a better or best driver update program out there that can backup my drivers into an executable so that when i reformat i can reload drivers. No I don to have drivers for my Dell XPS600 computer. Lost cd. Driver Genius does what i have said here, but I think there is something out there better(unless you guys think this is good). Driver Genius did not update for example my picasa software or my ESET NOD32 software, and i know there is updates for these. Thanks for the help.
i wouldn't pay for a driver update software. it's just as easy to go to the various manufacturer's websites and download them yourself. dell has all their drivers online. do it before re-formatting the hard drive and installing windows.
Exactly, go to the dell website the back of a tower/bottom of a laptop have a service tag on dells that gets you to the right drivers.
Why pay for free stuff. -
I see your point, but I thought that these programs updates all your software drivers, including the dell ones. I though it would be easier. I forgot to check Dell site, Dohh! But if you had to use one of these update driver programs, would you happen to know which one is better. I had reformatted my friends HP laptop, and even going to their site, it was a pain to get certain drivers. I figured a program like this would find them easier. Thanks again.
updating drivers is not the same or include updating software. drivers are only for the hardware in the box.
If you're set up doing it this way, try DriverMax (free) ... haven't used it extensively, but it allows you to created a stand-alone "restore" program that will re-install your current driver set into a "clean" OS after a re-build.
Trev -
Thanks TJohns, will try. Much appreciated. And thank you all for the advice.
Major problem with automatic updating is that an assumption is made that the latest update or revision is something that you actually want. Often, these Create more problems than they solve.
I do this all the time with various PCs, takes but a few minutes to find and download manually, get the set you need that works and burn it to a CD. By installing them manually, it is easier to pinpoint the one particular update or install that causes problems, rather than looking at a non-functioning PC that just had half a dozen updates, troubleshooting is much more involved.
I usually remove such auto-update programs when found. More dangerous than helpful.
VideoInspector updated to v2.3.0.126
By Kyle_Katarn in forum Latest Video NewsReplies: 0Last Post: 6th Nov 2011, 15:33 -
Comcast RNG110 IEEE 1394/Firewire Windows 7 64-bit Drivers/Software
By tgcujo in forum DVB / IPTVReplies: 4Last Post: 2nd Jun 2011, 20:32 -
Need software for BDA drivers
By VEBouto in forum Newbie / General discussionsReplies: 1Last Post: 30th Jul 2010, 09:07 -
Programs that Upgrade Software and drivers
By orfajackson in forum Newbie / General discussionsReplies: 3Last Post: 6th Jun 2009, 13:06 -
Updated TMPGEnc
By avz10 in forum ComputerReplies: 4Last Post: 24th Jun 2007, 13:20
