I just posted a question about audio tracks and discovered I could customize what audio/subtitles my disc will have based on the information found in the Video_TS. However, now I found a new problem. Prior to customization, the folder info reads in toast 10 "Menus: Yes". Once I being to delete certain videos/audio in the customization tab (under options in the Video_TS window), it quickly changes to "Menus: No" once a change to anything has been made.
So...
1.) I know the Video _TS folder contains menus.
2.) If I take of an audio track or bonus feature off, Toast no longer recognizes the folder contains menu information
3.) How can I prevent this from happening while still removing the unwanted features?
...help?...
The developers of Toast decided to always exclude the source menu when there is anything being modified for the copied DVD. They didn't want the possibility of someone clicking a menu option that goes to something that is no longer there.
Your only workaround with Toast is to create your own new menu. You do this by adding your VIDEO_TS folder to the DVD video setting in Toast 10 instead of the DVD video from VIDEO_TS setting. In this way you'll have Toast authoring a new VIDEO_TS folder so you can use Toast's menu styles.
Toast can't compress my TS folder
By Jeikobu in forum MacReplies: 9Last Post: 28th May 2011, 17:13 -
How do I make a menu for a video_ts folder that has no menu?
By ericg42 in forum Authoring (DVD)Replies: 5Last Post: 9th Jan 2009, 07:02 -
Another folder than Video_ts and Audio_ts
By claudiofran in forum Authoring (DVD)Replies: 12Last Post: 3rd Mar 2008, 14:39 -
No Video_TS Folder..
By NatalieR in forum ffmpegX general discussionReplies: 1Last Post: 5th Feb 2008, 11:53 -
Make menu for "VIDEO_TS" folder (files inside it)...
By Chana1 in forum Authoring (DVD)Replies: 18Last Post: 24th Jul 2007, 09:29
