I have been doing videography with my NEW Sony HDR-SR5 camcorder in a professional studio for green screen/chroma keying.
The camcorder has an HDMI output that I connect to my wide screen monitor via a HDMI to DVI cable so I can preview the live feed.
On the camcorder I use manual focus and other settings are also manual so I can make sure a particular setup always look good.
I also set the video quality to the highest setting which makes the output resolution 1440x1080 pixels.
(The resolution needs to be big so I can chroma key it better)
When I press Record, it renders the video to the internal hard drive in MTS (AVCHD) format.
This appears to be an MPEG transport stream that utilizes MPEG2 compression to help save hard drive space.
After all my test shoots, I download an MTS file from the camcorder using a USB cable and import it into Sony Vegas 8c.
When I preview the video in Vegas at full(best quality) resolution, the subject(person) in the video is slightly fuzzy and slightly unfocused. (But the live output on my monitor is not).
Questions:
* Is the MPEG2 compression making my video slightly fuzzy and unfocused?
* Can I get better quality by outputting the raw video feed directly from the camcorder to the computer using a Component video cable and a capture card? If so, what video capture card would you recommend?
http://www.amazon.com/Sony-VMC-30VC-Component-Terminals-Camcorders/dp/B0007XYIVC
* Or would I get better quality by outputting the raw video feed directly from the camcorder to the computer using an HDMI cable and HDMI capture card?
http://www.blackmagic-design.com/products/intensity/
The camcorder does not support firewire.
The usb is for transferring the files from the camcorder's hard drive. -
That camera uses AVCHD format, so it's not MPEG2. AVCHD is a flavor of h264.
Explain what you mean by "fuzzy". Can you take a screen capture and post it here?
No
Yes, but the hard disk speed requirements on your computer make it very impractical to do so. You'd need 3 hard drives running in RAID 0 to be fast enough to capture the uncompressed video coming from the camera.
If it isn't one thing, it's another
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 05:40 -
MPEG-2 Transport Stream
By avsubvert in forum Video ConversionReplies: 2Last Post: 7th Aug 2009, 12:39 -
Sony HDR-SR5 for alternative webcam?
By raysolomon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 3rd Mar 2009, 21:26 -
AVCHD(.mts-sony hdr sr5) convertions questions
By dragonstd in forum Video ConversionReplies: 14Last Post: 25th Mar 2008, 20:01 -
Editing in-camera with the Sony HDR-SR5/7/8
By jockewick in forum EditingReplies: 1Last Post: 26th Oct 2007, 17:12
