I'm having some difficulties with playing a VCD I recently made. It's my first one, so I followed the turorial word for word. After the tedious converting process, I went ahead and burned the VCD. When I went to put it into my DVD player (a Samsung that says right on the case that it supports VCDs), it said "no disk." Anyone have an idea what I am doing wrong? I'd hate for all that time to have gone to waste
Only recommendation I can think to make would be to use a higher quality CDR. I've found cheap green/blue disks sometimes don't work. also if you can look throught the disk in a high light enviroment, possibly the Laser of the DVD player can to.
Try Silver or Gold quality Disks.
i have used a brand called GQ(great quality)from FRY's they work on the
709 and the 711 model samsung.
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 21:15 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 12:15 -
Upconversion DVD player w/ S/VCD
By Clessoulis in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Feb 2008, 09:43 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 07:41
