hi all,
im just woundering if anyone knows of a way to reauthor a dvd but be able to keep the oringal menu vob
ive extracted the main movie as m2v, as well as the sound
was woundering if i could import the m2v file and the seperate audio track, then use the orignal vob menu and reauther, is this possible?
thanks to anyone who replys
This guide might have the answer you are looking for: http://jsoto.posunplugged.com/guides/VobBlanker/adding_menus/index.htm
Put simply:
1. Reauthor your M2V and audio (Muxman)
2. Open the original DVD in VobBlanker
3. Highlight the VTS containing the movie so it appears in the lower screen
4. Highlight the video in the lower screen and hit the Replace button to the right
5. Scroll to your newly authored DVD
6. Blank out (remove) anything you don't want from the original DVD - anything from FBI warnings to extras
7. Process
Exctract Subtitles from .vob -> Import into Sony Vegas or DVD-Architect
By mltwitz in forum SubtitleReplies: 4Last Post: 4th Oct 2009, 02:16 -
Program that allows direct VOB burning AND menus
By 6079 in forum Authoring (DVD)Replies: 8Last Post: 22nd Jul 2009, 05:15 -
Import multiple .VOB to VirtualDubMod
By ashwin.terminator in forum Newbie / General discussionsReplies: 0Last Post: 5th Apr 2009, 04:19 -
VOB to AVI to import into Premiere CS3
By newcomer1 in forum DVD RippingReplies: 6Last Post: 11th Mar 2009, 15:32 -
Home vid Vob files won't import
By JackT in forum DVD RippingReplies: 5Last Post: 8th Jan 2008, 00:29
