I have a Sony DCR DVD 505 and I just finalized a disc and it took over 8 minutes to do. Usually only takes about 2-3 minutes. After finalizing the disc, there is nothing on it now. So, I don't know if I finalized a blank disc or if it just wiped out everything I had on the disc. I didn't look at it before I finalized it. I am going through a stack of older disc and finalizing the ones I never got around to.
Now, to my questions. Is there anyway to repair this disc?
Next, how can I obtain a copy of the software (CD) that originally came with my camcorder? I have lost mine and I looked on the Sony web site and all they have is the upgrade. When I try to install it, it says it can't find the software installed. So, I need the original software period. I am going to try and copy off all of my remaining dvd's to the computer before I finalize them, just in case the camcorder is going south on me. I do not want to toast anymore dvd's.
When I hooked up my camcorder to the pc (Vista x64) it installed the camcorder (the drivers), but I have no way to get the video off of the camcorder through USB.
Any help appreciated.
Yes, I can, but the computer will only read it AFTER it has been finalized by the camcorder. I am trying to pull the video off somehow before I finalize the rest of the discs, in case the camcorder toasted that one disc. I do not want to loose anymore.Originally Posted by JohnnyMalaria
Oh, I see.
Via USB, does it send/has it ever sent it as MPEG2 or is it changed to MPEG1? -
That is a very good question. I have never hooked it up to the computer via USB before. I have had the camcorder for years now and never had the need to hook it up. It came with a cd to install the software with, but I haven't a clue where it is after all these years. So, if I cannot get a copy of that software or something else that will do it, then I will be unable to transfer via USB. I do not know why Sony does not put the complete software on their website. I don't know why they require you to have the cd in the first place, what happens to someone like me that looses the disc? Screwed I guess.Originally Posted by JohnnyMalaria
When the DVD camcorder format was announced, Sony said the target customer wasn't interested in editing. They just wanted a quick DVD. That was their attitude. The tools offered were primitive but did include a USB driver.Originally Posted by darkcyber
Sony Vegas and some other editors will import from a finalized DVD camcorder disc but I think you need the Sony software to import over USB. Maybe there are tools that allow an unfinalized disc to be read.
PS: I did a Google search "DVD camcorder USB import" and came up with leads you might check e.g. iMovie, FixYa, VideoStudio.
http://www.google.com/search?hl=en&q=DVD+camcorder+USB+importRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I hear you. It's not as if people are pirating camcorders...Originally Posted by darkcyber
I saw on their European website that you should contact support if you need a replacement CD. Worth a shot... (Also saw it on BitTorrent but I'd *never* do that...)
USB Video Capture Software?
By ChibiBoi in forum Capturing and VCRReplies: 6Last Post: 20th Sep 2012, 04:07 -
Software Order and use. Edit Sony Camcorder mpeg2 video.
By gerritv in forum Newbie / General discussionsReplies: 1Last Post: 22nd Oct 2009, 03:12 -
How to transfer video from Hi8 camcorder without USB output
By vd0m45ter in forum Newbie / General discussionsReplies: 3Last Post: 15th Feb 2009, 07:50 -
unable to pull up files from camcorder to PC
By cschinnerer in forum Newbie / General discussionsReplies: 5Last Post: 6th Nov 2007, 21:19 -
transferring camcorder video to pc harddrive via usb
By telmealing in forum Newbie / General discussionsReplies: 5Last Post: 9th Jul 2007, 12:54
