I am using Nero 5.0.3.5 to burn my VCDs. They burn succesfully but when I go to play them in my sony DVD it says NO DISC and it clearly supports VCDs. I'm sorry if this question is ansewrd elsewhere but I could not find it.
Make sure that your Sony DVD player supports CD-Rs. Depending on how old your player is, it may not support them.
Another Isue especially with SONY DVD-players is that some models are very sensitive to what brand of CD you feed them.
Strangely enough CD-RW's usually work, but only some brand CD-R's work.
Personally I now use Princo CD-R's as they work fine for me (and are quite cheap as wel)
(Of course not sure wether they're available where you live).
So use CD-RW's, try the Princo's or do some experimenting with other brands of CD-R's. -
What model number is that Sony DVD player?
What kind of CD-R media are you trying to get it to read?As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
wtf is a smv file?
By kingnat2 in forum Portable VideoReplies: 19Last Post: 11th Jan 2012, 23:14 -
Wtf ? Camcorder freezes !!! Please help !!
By prattacking in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 9th May 2010, 21:42 -
WTF is with Ebay?!?!
By Noahtuck in forum Off topicReplies: 7Last Post: 29th Dec 2009, 18:33 -
From the WTF? Files
By Soopafresh in forum Off topicReplies: 7Last Post: 19th Apr 2009, 15:46 -
wtf is it?
By zoobie in forum Off topicReplies: 10Last Post: 25th Dec 2008, 16:03
