I'm using MediaPlayer Classic, version 6.4.9.1. With all the MPEGs I've tried so far, when trying to capture a snapshot using File > Save Image... (Ctl+I) it fails with the obscure error message "GetCurrentImage failed, hr = 8000ffff". Whether specifying BMP or JPG, and whether playing or paused.
Anyone able to reproduce this please, or know whether it's a recognised issue?
Terry, East Grinstead, UK
	You could try the newer Media Player Classic Homecinema. I just tried it out and it works on my pc.
	MPC needs to be using vrm9 or vrm7 as the renderer, cannot use overlay as the renderer for screenshots (check the output options=>output) , as a result, the images will have a discoloration (will look duller with vmr9).
 If you want proper color sampling and quality you could do it through avisynth, and use AvsP to take screenshots to .png or .bmp
	Many thanks, that does the job nicely!Originally Posted by SanderMan
	Thanks but mostly over my head!Originally Posted by poisondeathray
 But as you plainly know your MPC, can I ask a different question please. In the new Home Cinema version, under Options > Player > Keys I see some entries like this:
 Command = Save Image (auto)
 Key = VK_F5
 What does 'VK_F5' mean please? IOW, what is this 'Virtual Key'?
  VLC / KMPlayer / MediaPlayer Classic... h264 DecodingBy triptych in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jul 2009, 13:17
  RealMedia/MediaPlayer ClassicBy JackPollack in forum Software PlayingReplies: 0Last Post: 18th Jan 2009, 20:36
  MediaPlayer Classic - wrong aspect?By terrypin in forum Newbie / General discussionsReplies: 6Last Post: 8th Sep 2008, 14:03
  MOV won't open in MediaPlayer ClassicBy terrypin in forum Newbie / General discussionsReplies: 4Last Post: 4th Sep 2008, 02:56
  avi: alright with mediaplayer, virtualdub failsBy engel in forum Software PlayingReplies: 14Last Post: 11th Aug 2008, 04:59
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
