Hi every body. I have big problem. The FPS of my Sub/Idx subtitle is not match with the FPS of my movie. and I did try by VobSub Cutter to resolve this issue. but my problem is that I can't find the correct FPS of my Sub/Idx subtitle. I know the FPS of my movie is 25. and when I open VobSub Cutter there is two place for entering FPS: Org and New. Org is for the FPS of subtitle and New is for the FPS of movie. I did try many times with different random FPS but it didn't work and I didn't reach a proper subtitle yet. Sorry about my english. plz help me if u can. thank you
Random wont get you there.
The three most likely candidates are 23.976, 25 and 29.970 fps. You know it isn't 25 fps, so try the other two.
You also have to make sure that the subtitles match the version of the film you are pairing them with. Same edit, same release. Different markets may have different distributor/producer logos at the start, which will throw out your subtitles.Read my blog here.
Only .idx subtitle supplied
By saymell in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2010, 00:17 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 11:25 -
about idx subtitle
By sg999 in forum SubtitleReplies: 4Last Post: 5th Nov 2008, 02:25 -
Burn IDX Subtitle ONLY to CD With AVI
By stoneferry in forum SubtitleReplies: 4Last Post: 22nd May 2008, 02:13 -
sub/idx FPS
By s_a_m4000 in forum SubtitleReplies: 1Last Post: 25th Nov 2007, 12:30
