I've build an ISO file with Pgc Edit and set the layer break. How do I burn with Nero 9? Do I have to set layer break again in Nero. Thanks
anfield7,
I agree with MOVIEGEEK and guns1inger. Nero sets the layer break wherever it chooses, which is just one reason it is a poor choice for burning dual layer. There is also no advantage (anymore) to using PgcEdit to set the layer break before handing off the burning chore to ImgBurn. You can select the layer break position and perform the burning from inside ImgBurn. You will also save yourself a lot of grief if you use only Verbatim +RDL media for dual layer burning.
Do Any Double Layer Disc Work With Panasonic DMR-EZ48V?
By cbehr91 in forum DVD & Blu-ray RecordersReplies: 13Last Post: 10th Jun 2010, 16:39 -
DVD+R9 Double Layer first burn: problems with layer switch
By Edmund Blackadder in forum DVD RippingReplies: 400Last Post: 4th Oct 2009, 12:27 -
Burning Double Layer Disc
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2009, 09:22 -
Need to burn my first double layer dvd EVER.... HELP !!!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 20Last Post: 25th Mar 2009, 17:42 -
How to burn 8.3G iso movie file to dvd double layer disc?
By ibearzz in forum DVD RippingReplies: 12Last Post: 21st Oct 2007, 20:47
