Hi. I have 4 720p MPEG2 videos from my tv card that I want to combine into a single video. The first video is 40 minutes and the other three are about 20 minutes in length.
After reading something on the internet (which i've forgotten where it was), my first idea was to transcode all the videos into h.264, then use MPEGStreamclip to combine them, but after close inspection i couldn't find the option in MPEGStreamclip to append video. The other problem with that solution is that h.264 transcodes take forever unless you have a powerful Mac Pro, which I don't.
If anyone can help me out here, that would be fantastic![]()
http://www.pcpodcast.org (Website Under Construction)
It's inelegant, but you should be able to copy, cut and paste MPEG2 videos straight in MPEG Streamclip without transcoding.
Something like open - select all - cut - open no.2 - paste clipboard - repeatGo off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh? -
I forgot to mention, I don't have the Quicktime MPEG2 plugin.
http://www.pcpodcast.org (Website Under Construction) -
That makes it more complicated.
What type of video do you need/want for the final version? Standalone MPEG2? MPEG2 in the context of an authored DVD? Divx? h.264? Don't care? This information is important, because the answer to that question constrains the choices of software.
Operating directly on MPEG2 requires the MPEG2 component from Apple, basically (there are other options, but no workable free ones that I'm aware of). So, you can transcode into an intermediate format (like h.264, as you thought of), stitch the result together with some appropriate tool, and either view the result, or finish off by transcoding to another format.
So, just as an example, you could use ffmpegX (not free, but certainly inexpensive) to convert to DivX in an avi container, merge the avi's, and then do whatever you want to do with that (including leaving it alone).
Or, you could pay Apple a modest sum, get the MPEG2 component, and use MPEGStreamclip to do the joining.
xmedia Recode - Combine multiple videos?
By TYLER08027 in forum Video ConversionReplies: 3Last Post: 20th Apr 2015, 17:55 -
How do I add a watermark to my videos on Mac?
By dominozero in forum MacReplies: 5Last Post: 1st Apr 2012, 12:35 -
Playing Videos on Mac vs PC
By Alienated in forum Software PlayingReplies: 5Last Post: 11th Mar 2012, 07:31 -
Recording videos for my Mac users?
By ballantyneguy in forum MacReplies: 3Last Post: 23rd Nov 2010, 15:59 -
Combine two videos to remove time-code?
By Jerry1964 in forum EditingReplies: 5Last Post: 31st Aug 2008, 06:51
