Hi!
I have a video with a 23.976 framerate, and an audio track from a DVD with a 25 fps.
of course, when i mux them, there is a desync...
so i would like to know how convert the audio track (ac3 5.1) losslessly
it appears to be the easiest thing to do here...
is that even possible to change the speed of the audio without complete conversion??
thanks for youy help![]()
Results 1 to 13 of 13
If it's an AVI file and you don't care about DVD compatibility you can just change the frame rate in the header of the file. Then mux the audio and video together.
Changing the runtime of the audio will require full a decode/encode cycle. -
Originally Posted by cedworld
https://forum.videohelp.com/images/guides/p1938368/audioscale.rar
Just unrar to a folder, run "AudioscaleGUI". or make a shortcut to it.
Almost lossless, it stretches or compresses AC3 by duplicating or deleting frames, not reencoding.
(Got the GUI from http://forum.doom9.org/showthread.php?p=797909#post797909, but the actual executable web page is dead now.) -
I don't know for sure if it always works -- but MKV also has a frame rate setting you can change with AVC video. Using MKVMerge to merge a short elementary h.264 video stream with an audio stream I was able to set whatever frame rate I wanted. Playback with MPCHC was at the chosen frame rate.
It also has a "stretch" value for the audio. But when MPCHC played a file with streteched audio it seemed to modify the video frame rate, not the audio. This might not have been so bad but it did it by pausing the video once every second to make the video match the audio. -
TFM Audio Tool can change 25 to 23.96(Pal to NTSC) I've used many times without problems.
Audio track shorter than video track in MPEG Video Wizard DVD?
By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 13:24 -
Converting 23.976 fps to 29.97 without changing video length
By Cman21 in forum Video ConversionReplies: 7Last Post: 16th Mar 2010, 06:09 -
24.000fps (not 23.976!) audio to 25fps
By Lastman369 in forum AudioReplies: 8Last Post: 13th Jan 2010, 08:58 -
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 12:01 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23
