Hey guys, I just joined the forum and I've tried the search function but I need a little direction.
I'm a very novice computer user who pulls wrenches for a living, and is trying to edit some old vhs movies of my band from the 90's so I can give the guys in the band copies.![]()
Here's what I've done so far:
1) I borrowed a friends vhs to dvd recording machine and copied the old tapes to disc.
2) I put the disc in my wifes new little HP computer and media player opens up and plays it! woo-hoo!!!
3) I open the windows movie maker to edit it and realize the only thing I can do with the disc in drive E is watch it! (%#$**!)
4) I google a little and figure that I should download dvdFab to convert this disc onto my computer.
5) I copy it with dvdFab and when I try to open it I realize I'm still a dumbass....movie maker still won't open it.
Sooo..... can anyone point me in the right direction. Should I give up on this or is there an easy way, final video quality isn't too big of a deal. I just want to cut out the crappy parts between songs.
Thanks for any help.
You don't need DVDFab DVD Decrypter in this case because you have a home made DVD that has no copy protection.
I would start with VOB2MPG, and use this to extract the video and audio from the VOBs on the DVD to your HDD as an MPG file. You may find that Windows Movie Maker will be happier to open this.
That said, Windows Movie Maker is really designed as a lowest common denominator freebie option, so it can be difficult to get it to edit anything other than WMV and DV AVI files.
Also not, it will re-encode everything if you don't start with WMV or DV AVI files, and because it is not a high quality tool, this will cost you quality. You may be happy with this, or you may not.
If you aren't you might consider alternative editors, such as VideoStudio X2 (corel) or Womble Mpeg Video Wizard, which will edit Mpeg-2 video with minimal re-encoding.Read my blog here.
If you are going to use Movie Maker, I strongly recommend you read and bookmark Pap John's site : http://www.papajohn.org/
Also, download and install his output templates, as they can increase output quality substantially.Read my blog here.
Thanks for that link, seems like a great site for novices.
Howdy,VHS to DVD and I want edit to get rid of the dross and add voice over
By rabbithutch in forum Newbie / General discussionsReplies: 3Last Post: 15th Apr 2011, 18:12 -
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 09:28 -
VHS to DVD OR HARD DRIVE TO EDIT WITH THE BEST QUALITY
By jakeconnor in forum Capturing and VCRReplies: 11Last Post: 9th Jul 2008, 22:04 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 14:13 -
I was told I need to preserve and edit some old VHS family tapes...
By Dash1 in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2007, 17:17
) to half-ass edit these for the boys.
