I have recently downloaded four movies in avi format. UNfortunately the TMPGE program will not recognize these files even after I manipulated the environment/VFAPI Plug-In settings. I can find no other advice on this site or others. Are these movies incapable of being converted, or is there another program I could use? All I know is that these files have an avi extension and play fine on Windows Player. Please Help.
can you play it in Media Player? if you can't then bkoyle is right you need the correct codec
usually if you can play it in Medai Player you can convert it in TMPGEnc
most commonly missed codecs for downloaded movie are DivX (get both versions)
3.11 Alpha -- http://planetmirror.com/pub/divx/windows/divx_3.11alpha.zip
Open DivX -- http://www.divx-digest.net/software/codec/divx4betacodec.exe
and SMR
http://www.divx-digest.net/software/codec/smrpatchsetup.zip
<font size=-1>[ This Message was edited by: Stinky on 2001-07-23 19:40:10 ]</font>
Exactly what goes on in conversion?
By Haopengyou in forum Capturing and VCRReplies: 1Last Post: 2nd May 2011, 11:52 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55 -
Conversion Help
By slayer_of_all in forum Newbie / General discussionsReplies: 2Last Post: 8th Apr 2010, 10:45 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 19:36 -
Conversion
By firoril in forum Video ConversionReplies: 1Last Post: 2nd Aug 2007, 11:46
