Hi,, I have a french movie that came with english subs,, It came to me in an .avi format and a seperate folder with the english subs on it, if there a way to burn a movie like that using Nero or Roxio 2009?? or do I need a another software? if there is whats the software I need for this kind of project??
To begin with, I would recommend against the use of Nero or Roxio, as there are far better tools available. They may not look as pretty, but they are reliable, better quality, and much smaller.
ConvertXtoDVD (not free) is probably the easiest solution. FAVC, DVD Flick or AVStoDVD are other, freeware, alternatives. These will all produce a working DVD, ready to burn.
Burn the DVD to a quality disc with Imgburn (freeware).
The only potential stumbling block is the subtitles. What format are they ? Not all programs handle all subtitle formats.
Finally, if your DVD player can handle Divx/Xvid encoded AVI files, it may well be able to read the subtitles as well, if they are named correctly. Generally this means movie1.avi, movie1.srt (for example).Read my blog here.
comes with 2 files and *.idx and *.sub files i'm trying to incorporate those 2 file for the movie.. what can i use??
You're too vague about what you want to do. When you play the AVI, don't you see the subs? If not, install DirectVobSub. Is keeping them separate while playing the AVI enough, or do you want to burn them into the video? If you want them embedded, then a full reencode will be needed. If for AVI, open the AVI in AutoGK and then use the F8 trick to add in the subs. Here's the Baldrick guide for that:
https://forum.videohelp.com/topic316471.html
If you want to convert the AVI to a DVD with selectable subtitles, there are many programs for that, but since I don't use any of them, I don't know which ones can use IDX/SUB files, or require you to OCR them to some text based subtitle format. Someone else can help you there. Just tell us what the final format is to be (avi with burned in subs, DVD with selectable subs, or something else entirely). -
ConvertXtoDVD will definitely convert avi with sub/idx subtitles to DVD. It is a little confusing to use, but it will do the job. Before you use it, though, play the avi with sub/idx (total of 3 files in the folder) and make sure the subtitles play correctly on your computer. Make sure you have Vobsub installed on you computer.
BD rip to .mp4 with foreign only subs burned in.
By bonnstettermark in forum Blu-ray RippingReplies: 14Last Post: 14th Mar 2012, 11:44 -
English subtitles for the movie
By Alexandr23 in forum SubtitleReplies: 0Last Post: 28th Dec 2011, 06:39 -
removing subtitles (foreign language) from a downloaded movie
By gizmobently in forum Newbie / General discussionsReplies: 3Last Post: 26th May 2010, 23:40 -
How to get rid of the foreign language voice in a movie?
By electrical_engineer in forum Newbie / General discussionsReplies: 3Last Post: 13th Jan 2010, 08:20 -
newbie help for foreign subs
By A-thru-Z in forum SubtitleReplies: 1Last Post: 19th May 2007, 09:29
