I am going to edit a three camera HDV shoot. The source video files that are available to me are Matrox AVI files. The tapes are no longer available. The files were captured by someone who uses Premiere Pro CS3 with a Matrox board. Will Sony Vegas Pro 8 recognize the Matrox AVI codec? If not, are there any transcoding tools / tips? I assume these must be uncompressed AVI files but I don't know if there is anything unique about the Matrox codec.
I'm pretty sure the Matrox codec is a mjpg variant (at least the one for capturing; there is a DV version too), you can double check with mediainfo and rule out that it's not some other bizzare implementation. If Vegas doesn't play nice with importing natively, you could use a lossless intermediate (e.g. use ffdshow to decode the matrox => encode to lagarith in vdub)
I had some Matrox DV clips (Type-2 avi), and they worked fine in Premiere. AviCodec identified the Matrox clips as "Sony dvsd." I would think the clips would work in Vegas -- but you're talking about an HDV project, so I can't be too sure.
Vegas changing colors of mts files on import. Not levels.
By banditeer in forum EditingReplies: 37Last Post: 10th Oct 2010, 08:28 -
Vegas Pro - AVI (H.264) - Can't import!
By besweeet in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2009, 22:10 -
How to Import Matrox AVI Files into Vegas Pro 8
By SCDVD in forum EditingReplies: 1Last Post: 22nd Mar 2009, 20:57 -
Using Matrox .avi files in Vegas Pro 8
By SCDVD in forum EditingReplies: 1Last Post: 20th Mar 2009, 16:43 -
Cant import AVI files into Adobe Premiere Pro 1.5 (again)
By Undead Sega in forum EditingReplies: 1Last Post: 13th Oct 2007, 21:35
