Iam going to rip about 400 DVD into a mediaserver, tht will tke several days, but im looking for a good program that gives me uber quality wth the lowest siz of files
Quality, small filesizes and speed don't go together.
Quality encoding takes time. Only a fast CPU will reduce this. You have no specs, so I don't know what you have.
Filesize and quality are a balancing act. Filesize is determined by bitrate and running time. As running time is a constant, bitrate is all you can vary. The lower the bitrate, the lower the quality (generalisation, but true enough for this conversation)
Best and fastest results are generally gained by ripping the DVD to your HDD first, preferably stripping off any crap you don't need first. DVDFab HD Decrypter is good for this. Use the movie only mode if that is what you need.
Encoding depends on what format you want/need, what you are playing back with (specs ?) and what you are playing back on. You say you want 'uber quality'. This implies slower encoding, probably using H264 as the video codec.
I would suggest you work in batches. Rip a number of DVDs to your HDD, then use an encoder that has a batch facility to encode these one after the other, probably over night.
I like Xvid4PSP, but there are many other choices. What works best for you will depend on what you really want, which at the moment is a bit vague.Read my blog here.
Fastest & easiest way to convert files from dvd to upload to Youtube?
By scarypoultry in forum Video Streaming DownloadingReplies: 2Last Post: 6th Jul 2010, 03:49 -
Easiest, fastest way to convert MKV to Blu Ray with 1080p aspect ratio
By jfk8680 in forum Authoring (Blu-ray)Replies: 3Last Post: 13th Apr 2010, 00:07 -
Whas is the Easiest to Use DVD Ripping Program?
By Gatimo in forum DVD RippingReplies: 4Last Post: 13th Jan 2010, 22:23 -
How to join m2v, the easiest and fastest way?
By hanugro in forum EditingReplies: 10Last Post: 4th May 2009, 07:32 -
Easiest and fastest way of converting MKV files to be played on HDD player!
By kebabtomten in forum Video ConversionReplies: 2Last Post: 2nd Dec 2008, 22:33
