Im demuxing my .TS ( HD PVR ) with DGAVC Index and the file name for audio is like
movie.dga PID 1100 3_2ch 48KHz 384Kbps DELAY -68ms
how can I fix that to not have DELAY ?
You can't with DGAVCIndex, at least not directly.
You can use tsmuxer to demux, which will apply the delay by default (you can adjust the delay, or no delay; just highlight the audio track and select the option). For the HD-PVR streams, you usually have to rename the audio extension
Demuxing Problem
By jpmccusa in forum Authoring (DVD)Replies: 8Last Post: 18th Mar 2010, 20:10 -
Demuxing
By ckurowsk in forum Authoring (DVD)Replies: 5Last Post: 23rd Jul 2008, 18:04 -
what to do after demuxing?
By azizbhimani in forum SubtitleReplies: 2Last Post: 24th Feb 2008, 22:39 -
Problem with Demuxing
By Elvish Hero in forum Authoring (DVD)Replies: 3Last Post: 17th Jan 2008, 04:56 -
Demuxing an .MOV
By legodude in forum Newbie / General discussionsReplies: 1Last Post: 25th Jun 2007, 01:44
