Theres no sound on my dvd when I play it on a standalone dvd player(tried different player) but it works fine when I play it on my PC.Is there anyway I can fix the audio to work on standalone?
	PLEASE give us as much INFORMATION as possible.
 How did you make the DVD? HOme made? Commercial dvd? What software ? etc
 What is the audio codec in the dvd? Use mediainfo and open the dvd/vob, change to View->Text and copy and paste the result in this topic.
	Homemade dvd created by unknown
 Audio
 Format : AC-3
 Format/Info : Audio Coding 3
 Duration : 57mn 12s
 Bit rate mode : Constant
 Bit rate : 192 Kbps
 Channel(s) : 2 channels
 Channel positions : L R
 Sampling rate : 48.0 KHz
	Does your standalone DVD player have options for selecting different audio tracks? Some standalone recorders default to odd choices. Yours could be one of them (or the default got set funny along the way). Simply choosing a different audio track (from your remote control) might take care of this.
	I had a problem like this once. Don't know if it will solve your problem. Somewhere hidden in the DVD player settings menu there might be different options for speaker setup. Try selecting different options and see what happens.
  What is the best virtual surround sound from a motherboard or a sound-card?By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03
  Audio Sound File Saved - Canot Hear Sound - Total RecorderBy Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29
  Need advice getting rid of buzz sound at end of every word of video soundBy OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58
  Remove Sound From Original DVD And Add My Own Sound To New DVD.By MrJacobAngle in forum Authoring (DVD)Replies: 7Last Post: 30th Jun 2010, 15:38
  DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
