Hi everyone,
I have a HDD that is on the verge of dying -- I am trying to find a software that can clone the disk so I can preserve all the installed programs and such. But seems like all the current utilities (Ghost, True Image, etc.) are XP/Vista only. Does anyone know if there are still any reliable cloning software available for Win2K? Any help will be greatly appreciated. Thanks in advance!
Spiffy
Ghost (at least up to version 8.x) included a DOS version also...I regularly use a DOS boot floppy or CD to clone NTFS partitions - GHOST will read the partitions itself (calling it something like 3:2 for disk 3 partition 2) even though DOS doesn't support them.
I've recently used SelfImage quite succesfully for the same issue on my brothers PC. I've got a USB2 external enclosure that I put his drive in, created an image file on my PC of the old drive, put a new drive in the USB2 enclosure, wrote the old image to it. Worked great. 20gb took about a half hour to copy, little faster to put back if I remember right.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
Hence the reason he said current versions. 10 is not the current version of Acronis True Image, Acronis True Image 2009 is. Their web site states:Acronis True Image v 10.0 runs perfectly on my W2k machine
System Requirements:
* Windows® Vista;
* Windows® XP Professional x64 Edition;
* Windows® XP SP 2;
http://www.acronis.com/homecomputing/products/trueimage/requirements.html
Same with Ghost. If Ghost still comes with the boot disk utility - which I believe it does since it supports Linux - you can clone win2k. It really seems odd that they would drop support of win2k. -
Yes, but why (specifically) would you need to go to the later version ? Acronis 10 is still a good solution for me, in tandem with W2K. I also use the shareware DFSEE for cloning and other hard drive work, though it is not as simple to use as Acronis. It handles some things that Acronis (TI or Disk Director) don't, and vice versa -- which is why I want them all in my toolkit. It includes multiple platform versions (one for Linux among them), and does not dis-inherit older OS versions like W2K in the course of its regular, free updates.Originally Posted by RLT69Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
Cant get rid of double imaging?
By killerteengohan in forum DVD RippingReplies: 22Last Post: 13th Aug 2011, 05:52 -
cloning winXP system disk problem
By deejay.2001 in forum ComputerReplies: 1Last Post: 15th Jun 2009, 15:54 -
What is the best dvd cloning free software for the mac?
By Jabroni4872 in forum MacReplies: 9Last Post: 7th Nov 2008, 10:10 -
Is there easy way to create Win2k boot disk with command prompt available?
By bevills1 in forum ComputerReplies: 9Last Post: 10th Apr 2008, 11:25 -
MPC software for playing DivX videos on Win2k
By Fredw in forum Media Center PC / MediaCentersReplies: 1Last Post: 20th Jun 2007, 15:14
