i got a question that i hope someone can answer for me. i have been using dvdfab (always current version) to rip my dvd to my hard drive then i use dvd shrink 3.2 to reauthor my dvd and use that to burn to verbatim dvd - r disc. i am using nero 8 as my burning software. only for a long time now i can't make a dvd just using dvdfab then dvd shrink to reauthor and burn. all i get are dvd's that won't play in my dvd players anymore they will only be recognized and play in my laptop drive only. to make a dvd that will play in my dvd players i have found i have to do a extra step now i use dvdfab first then dvd shrink to reauthor to a empty folder with no dvd-r in the rw drive, when dvd shrink is done backing that movie up i have to use the backup folder instead of the directly ripped movie folder which will be a 4.37gb movie then use nero itself using nero express selecting dvd files to burn and burn that way. i never had to do it this way and it takes longer to rip and burn my dvd's now. any idea why now i have to do it this way? i have been doing it the regular way for a couple a years now and never had a problem before, i kind of wonder if it is in nero itself since i think since i used to use nero 7 and never had a problem till i upgraded to nero 8. anyone heard of this happening or anything like it? thank you for your help.
Results 1 to 9 of 9
Use IMGBURN to burn your dvd media. NERO is crappy to use end of story. When using DVD SHRINK you can output to a ISO image then just pull up IMGBURN to burn that ISO file that you created with DVD SHRINK. One more step isn't that difficult.
Use the special version of DVD Shrink + ImgBurn
Hacked DVD Shrink: dvdshrink32%20setup%20imgburn.zip
ImgBurn: http://imgburn.com/index.php?act=downloadWant my help? Ask here! (not via PM!)
update: last night i had to think as to when i first had trouble with this and i really thought it was when i upgraded to nero 8. so i thought i would try something i uninstalled nero 8 and went back to my oem disc nero 6 and lo and behold they are burning correctly now and faster 20 minutes to rip and 20 minutes to burn. it works better than has ever done so thanks for the advice i hope this helps someone.
Besides, sscottsa315's Nero 6 is an OEM version, so it's most likely keyed to that drive, anyway, and won't work if that drive isn't in the system.
Nero 8 should have worked okay with that drive - in theory - but it wouldn't have been specifically designed to work with it as the OEM 6 install was.
But, yeah, I'll add another vote for Imgburn.
avi.net backing up Iron Man 2 DVD>divx audio problem (SOLVED)
By crazifunguy in forum Newbie / General discussionsReplies: 7Last Post: 1st Nov 2011, 00:11 -
Problem backing up Blu-Ray using BD Rebuilder with milOtis method
By TJMac44 in forum Blu-ray RippingReplies: 15Last Post: 7th Mar 2011, 15:43 -
Problem backing up my copy of transformers 2,i got it ripped but can't burn
By sscottsa in forum DVD RippingReplies: 1Last Post: 22nd Oct 2009, 19:18 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
DVD Burning And Hard Drive Backing up..
By Mastablastacious in forum ComputerReplies: 15Last Post: 19th Jan 2008, 03:30
