I have a Sony Handycam DCR-HC42. I have recently started streaming my videos to my pc via usb and using windows video maker. The first batch I did worked fine. I used the largest setting for videos and got passable image quality and sound quality.
I recorded a new video over the same tape and attempted to stream it to my pc. Unfortunately the quality on the pc has dropped drastically. Now it appears very pixelated and basically an indistinguishable blob. The lcd display on the camera shows the same quality images as it did before. Did something happen to my usb connection to slow it down or do my heads need cleaning? Any help would be much appreciated.
Results 1 to 11 of 11
Have you verified any quality settings on the camera? As most cameras use a small LCD for viewing, you aren't likely to notice any difference in a low quality recording and a high quality recording.
Google is your Friend -
I have tested using footage that i have streamed before. Before I got a great picture, now, the exact same tape and footage comes through very pixilated and low quality. it is like my windows movie maker program is messed up. i wonder if i can re-install it.
as stated above, i have successfully transfered via the usb cable before. if i had a firewire cable i would use that but i dont.
a firewire cable is cheap and there is no other way to get full resolution video off of a minidv.
Ok i hooked the camera up to my tv and played the video back and the image quality is great. i am convinced i have changed a setting in the camera itself for the usb streaming or something is corrupt in the windows movie maker software. can anyone recommend a free capture/movie software other than that? any ideas what settings i could have changed in the camera it self?
i know firewire will get me the best performance but i am just looking to get back to where i was
thanks -
the 42 manual says something about adjusting the picture quality slider setting in the "picture package" software that came on the cd with the cam....
YOU ARE MY HERO!!!!!!!!!!!!!!!!!!!!!!!!!!!!
This fixed it. All I had to do was re-install the Picture Package Software and my resolution came back. THANK YOU SO MUCH!
I knew you guys could figure it out.
Thanks again!
Transfering Video from Sony DCR-TRV250 by USB on Win7 64-bit
By madadivad in forum Capturing and VCRReplies: 5Last Post: 7th Dec 2011, 17:52 -
Sony Handycam DCR-HC42 can no longer read/write to tapes
By tgp1994@gmail.com in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 11th Jan 2011, 17:09 -
DCR-HC42 Transfer Still Images from Tape
By MichaelRD in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2010, 23:09 -
Sony DCR-DVD92E Recording
By Pea in forum Video ConversionReplies: 2Last Post: 17th Sep 2009, 11:15 -
Video capture with DCR-PC110E (via USB?)
By _mAyDaY_ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jul 2008, 09:15
