Hey there. I recently download MTR and DVD2oneX2 for backing up dvds. It worked grea the first four times, then when I put in an anime box set disc I had bought at best buy, it said the VOb was made deliberatly with errors ad asked to pad or delete it. I padded it and when I went to compress it in X2, it stopped halfway through.
My questions:
How can I fix this VOB problem (if possible)? Why is this happening?
Are there other (descent) rippers for Mac that I can convert to working, quality DVDs? I don't mind spending (a little) money, but I want to make sure it works.
	You are using an old version of MTR. MTR 2.6.6 doesn't work on most of the newer discs. The newest one (right now) is MTR 3.0 R14m. If you want to update, go to RipDifferent.com and read Annoucenments #1 and #2 in the MacTheRipper Forum.
  MacTheRipper - couple of probsBy satcure in forum MacReplies: 3Last Post: 24th Aug 2010, 15:44
  confusion with mactheripper, perian & handbrakeBy yoly in forum MacReplies: 4Last Post: 7th Feb 2010, 03:48
  MacTheRipper/PopcornBy monieeka in forum MacReplies: 3Last Post: 21st Jul 2008, 03:39
  Single vob file in MacTheRipper?By bmoney017 in forum MacReplies: 2Last Post: 20th Oct 2007, 03:07
  i'm really new, i have no idea what happened with mactheripper: dvd to fcpBy relativist in forum MacReplies: 6Last Post: 5th Oct 2007, 20:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
