Hi, sorry if this is somewhere already but my search got nowhere.
I have burned many cds with an avi file and its subtitle inside the same folder to play in a standalone DVD player. The subtitle has exactly the same name as the avi file, except for the extension which is usually either .srt or .sub. But now I want to put 2 different subtitles so I can choose one or the other for playback. Since they can't have the same name in the same folder, how should I do this ?
Thanks,
Results 1 to 27 of 27
Wendy ? I'm home !
The way to do it with software players like VLC is to add a language identifier to the filename. But I kinda doubt that many set top player will handle it like that.
Code:folder movie-name.avi movie-name-en.srt movie-name-fr.srt
This is a frequently encountered problem, and as you have discovered, there does not appear to be a simple solution that works for typical standalone players. What I've been forced to do in these situations is simply to burn two separate discs, each with its own subtitle file. Discs are cheap, and the lack of a workable alternative leaves you with few options.
I've not tried this, but according to the manual for my Pioneer DV-600 "The number of external subtitle files which
can be switched for the same movie file is limited to a maximum of 10".
Not sure how, when it supports only four (ie: srt, .sub, .ssa, .smi). Perhaps you could try this:
Movie.avi
Movie.srt
Movie.sub
Where .srt is one langauge, and .sub is the second language stream? -
Another thing you could try is to mux the subtitle files into the AVI as subtitle streams, though I don't know offhand how you'd do that on a Mac, then the player might let you switch between the subtitle streams when you're viewing the AVI.
Also, for experimentation, it might be better to use a CD-RW for testing, until you're sure what will work with your player.If cameras add ten pounds, why would people want to eat them? -
Thank you all guys.
-John-Paul= I might try that, but aren't sub and srt different kinds of files ? If I have one English .srt and one Spanish .srt, can I just take one of them and rename it .sub ?
-ffooky= It's an LG, DVF-9900 N
Regards,Wendy ? I'm home ! -
soundchaser - I can't find a manual for your player but if you have it, check which subtitle formats are accepted. I've just checked my Philips and it accepts the 4 varieties that John-Paul listed and .txt, which would be perfect. I believe there are 4 different subtitle formats with the extension .sub and only 1 (AFAIK) is not text-based, the sub + idx combo. Jubler can convert between the text-based formats.
Thanks a lot, ffooky, but supposing it accepts all the formats, my question then still is what I asked John-Paul:
If I have one English .srt and one Spanish .srt, can I just take one of them and rename it .sub ?Wendy ? I'm home ! -
Oh sorry, you'd said that already ! Thanks, I'll try it all out and let you know.
Cheers,Wendy ? I'm home ! -
Originally Posted by Ai HaibaraWant my help? Ask here! (not via PM!)
Yeah, but I didn't think the OP would want to do that, when the videos already play on the player with no problem.
Besides, doesn't Toast and a handful of other OSX apps do much the same thing?
Certainly. I'd still want to see if soundchaser's LG supported AVIs with muxed subtitle streams, though.
I could only find a spanish manual for the LG DVF-9900N, but if the english equivalent is the LG DV-9900 then you may be in luck, excerpts from the manual below:
Subtitles: DVD / Divx
Press Subtitle repeatedly during playback to see the different subtitle languages.
Playing a Divx Movie Disc
Playable Subtitle Formats:
SubRip(*.srt/*.txt), SAMI(*.smi), SubStation Alpha(*.ssa/.txt), MicroDVD(*.sub/*txt),TMPlayer(*txt), Dvd Subtitle System(*.txt), VobSub(*sub) -> sub/idx.
This would seem to indicate that multiple subtitles can be achieved for Divx playback on this unit, its just a matter of identifying the correct approach...
I'd also be interested to hear whether something like AVIAddXSubs would work, but you may need some sort of crossover to work on a mac. -
AVIAddXSubs might work, if the LG has DivX Ultra support.
I have he manual, but of course it doesn't mention how to organize the multiple subtitle issue to burn the Divx -if it did I wouldn't be posting !- it just mentions that you can press repeatedly the subtitle button to switch among the available languages, as on a DVD. And also lists the formats supported, which are the ones John-Paul wrote and another one called SubViewer.
I'll burn CD's and try them out on the LG during the weekend and let you know. Thanks again folks !Wendy ? I'm home ! -
The other alternative (which I tried today and works on my Pioneer) is to extract the two subtitle streams via vobsub into sub/idx format.
- Vobsub configure
- open the relevant ifo
- in the drop down ensure both languages are included
- ok.
Then burn your cd folder as:
*.avi
*idx
*sub
Then when you select the subtitle button on the remote it should switch between the two subtitle streams. -
Originally Posted by Case
Mac OS 10.4.11 (TIger) / Toast 9 / Data DVD recorded as DVDROM-UDF.
Amongst other data files, a folder containing=
-MovieName.avi
-MovieName.ENG.srt
-MovieName.SPA.srt
This, with an LG DVF-9900 N plays fine, and switching between English and Spanish subtitles worked perfectly, as if it were a DVD video. I didn't watch it all, but the first part and fast forwarding somewhere halfway through still worked ok.
So then, thanks Case and of course all the rest of you guys ! "Case" closed, though I'll be glad to give any more details if anyone requests.
Oh, .srt actually...I already corrected my previous post which said ".sub"
Originally Posted by soundchaser
MovieName.avi
MovieName.EN.srt
MovieName.PT.srt
Except, this didn't work for me. It plays only the English subtitle and won't let me switch to the Portuguese one. In VLC, it works fine! But on my DVD player, it doesn't. Do you guys have any suggestions for me? -
Are you sure your player supports more than one external subtitle stream per video? Most standalone DVD players I encounter usually only support one. (Check the manual.)
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
choose the appropiate codec for display an AVI File in Windows OS
By htamayo in forum Newbie / General discussionsReplies: 3Last Post: 20th Jun 2008, 14:33 -
Help with how to choose audio stream in avi to dvd conversion
By hibbs in forum Newbie / General discussionsReplies: 3Last Post: 25th May 2008, 23:50 -
What AVI File Size Should I Choose
By Dubinvero in forum EditingReplies: 2Last Post: 22nd Sep 2007, 22:05 -
how do i choose the right audio track going from avi to dvd output?
By kenzo69 in forum ffmpegX general discussionReplies: 3Last Post: 23rd Jul 2007, 19:36
