What are the best settings for AVStoDVD? I'd like to convert .avi files that are high quality to dvd so that it's still in great quality!
Thanks!
AVStoDVD will generally work out the best settings for your video. Quality is most dramatically affected by bitrate, so if you keep your running time to around 2 hours or less (i.e. 1 movie, 2 50 minute episodes or 3 40 minute episodes), the quality will generally hold.
The two major adjustments I make to the settings are
1. Ensure you have the target format (PAL/NTSC) matching the source. I hate format conversions, and they will affect quality if not done well. I don't know if AVStoDVD uses the pulldown method for format conversion, so I avoid it.
2. I set the bitrates to be higher than AVStoDVD has by default, however it seems to set the correct bitrates regardless, so this may not be necessary.Read my blog here.
It uses DGPulldown.I don't know if AVStoDVD uses the pulldown method for format conversion, so I avoid it.
To the OP, do note if you are a die hard 2 pass HCenc fan (many are) be sure to lock it in. For at higher bitrates (shorter runtimes) AVStoDVD may default to QUenc.
Are my AVStoDVD settings wrong?
By ehunter in forum Video ConversionReplies: 13Last Post: 17th May 2017, 23:32 -
AVStoDVD 2.4.0
By Hoser Rob in forum Authoring (DVD)Replies: 0Last Post: 30th May 2011, 21:37 -
need help with AVStoDVD settings to make best quality video for DVD
By granturissimus in forum Newbie / General discussionsReplies: 4Last Post: 29th Jan 2011, 17:00 -
AVStoDVD: How do I make default settings for all files to aspect ratio 4:3?
By Heyjoojoo in forum Authoring (DVD)Replies: 8Last Post: 30th Aug 2010, 23:49 -
AVStoDVD
By Dooker in forum Authoring (DVD)Replies: 10Last Post: 24th Aug 2009, 08:29
