I have mp4 video from digital camera and separate recorded sound in adobe audition. I am trim video in solveig avi trimmer and audio in audition to same point. But, audio and video have totaly different durations. I am try to extend audio in audition to lenght video, but again, all is out of sync.
I want simply montage audio to video!!!!!!!!!!!!!!!!!!!!!!!!!! Hoooowwwwwwwwwww????
here is info about vieo from mediainfo:
General
Complete name : F:\333\napred izrezani.avi
Format : AVI
Format profile : OpenDML
File size : 1.79 GiB
Duration : 1h 53mn
Overall bit rate : 2 252 Kbps
Video
Format : MPEG-4 Visual
Format profile : Simple@L2
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 53mn
Bit rate : 2 181 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4/3
Frame rate : 29.970 fps
Resolution : 24 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.237
Stream size : 1.73 GiB (97%)
Audio
Format : ADPCM
Format profile : U-Law
Codec ID : 7
Codec ID/Info : CCITT U-Law
Duration : 1h 53mn
Bit rate mode : Constant
Bit rate : 64.0 Kbps
Channel(s) : 1 channel
Sampling rate : 8 000 Hz
Resolution : 8 bits
Stream size : 52.1 MiB (3%)
Interleave, duration : 1000 ms (29.97 video frames)
audio info from mediainfo:
General
Complete name : F:\333\grobnik izrezano.wav
Format : Wave
File size : 1.12 GiB
Duration : 1h 53mn
Overall bit rate : 1 411.2 Kbps
Audio
Format : PCM
Codec ID : 1
Codec ID/Hint : Microsoft
Bit rate : 1 411.2 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Resolution : 16 bits
Alignment : Split accross interleaves
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 1 of 1
Converted video (mp4): audio out of sync
By darknezx in forum Video ConversionReplies: 4Last Post: 22nd Mar 2011, 02:25 -
Audio/video out of sync after converting (avi to mp4)
By Foxy Gogo in forum Video ConversionReplies: 1Last Post: 10th May 2010, 12:13 -
FCP MOV to x264 produces separate Audio and Video MP4 output files?
By skywriter in forum ffmpegX general discussionReplies: 3Last Post: 10th Feb 2010, 15:49 -
Sample error on separate source means video & audio out of sync!
By christowe in forum MacReplies: 3Last Post: 13th Jan 2009, 13:22 -
AutoGK- Audio Video completely out of Sync
By src2206 in forum Video ConversionReplies: 2Last Post: 8th Feb 2008, 10:49
