I'm using Surcode to make dts audio for dvd movies. It's fine until now. The movie is 3hrs 15min but when converted it is (minus) -2hrs 57min. Why?
I've never done this, but you haven't provided enough information. If someone is able to help, they will need to know your process, source file type, and all of the tools used.
Google is your Friend -
I'm using DVDLab Pro2.3. After demuxing, I use BeLight to split the audio to 6ch wav. After that I use Surcode to convert to DTS. As I've mentioned the movie is 3hr 15min but after conversion I open the DTS file in DVDLab but it shows (minus) - 2hr 57min, why? Thank you.
Check the length after each step in the process and you should be able to identify which step is causing the problem.
What does a time based corrector actually correct?
By Rudyard in forum Capturing and VCRReplies: 15Last Post: 26th May 2010, 06:45 -
Joining Subtitles with Correct Time
By sambat in forum SubtitleReplies: 2Last Post: 9th Sep 2009, 14:43 -
Settings Correct? Taking a Long Time/.avi to DVD
By 5Buffalo in forum ffmpegX general discussionReplies: 3Last Post: 24th Dec 2008, 14:29 -
Any way to correct NTSC DVDs that are time compressed?
By PBear in forum DVD RippingReplies: 9Last Post: 2nd Aug 2008, 18:02 -
Clock will not stay set to correct time
By driley in forum DVD & Blu-ray RecordersReplies: 15Last Post: 28th Mar 2008, 00:20
