When choosing layer break in Img Burn, all layer break available shown is average only. How to make layer break with excellent or very good to choose from? I'm using DVDLab Pro. Thanks.
Just preview them and see where they fall. I had a concert video that had multiple opening logs, trimming off one was just enough to move the layer break into a black transition scene. The opposite might also work... adding some black at the start.
When I preview the cell there was a pause. I've tried a few of the selected preview all of them have a pause. Is this normal? Thanks
Use PgcEdit to select break. Use the guide on this site (Blutarch made it, I think his name was.)
Did you try using the Seamless option?Originally Posted by anfield7
Create Layer Break Position in DVD Flick / Img Burn
By Akhet in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2011, 10:44 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 13:26 -
Setting the layer break on a DVD9 (DVDLab Pro project)
By lorix in forum Authoring (DVD)Replies: 4Last Post: 13th Nov 2008, 11:19 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 12:27
