I converted a 750 MB divx-avi file to Mpeg1 to burn it to a VCD using Tmpgenc and ended up with a 1.3 gig Mpg file that won't open in media player or in Tmpgenc for cutting it up int two CD's....It worked fine as the AVI file but now just sits there for hours saying "opening media" and still won't open...I have used Tmpgenc many times and it has never let me down...Won't Tmpgenc or maybe even Windows recognize a video file that large...It's just one of those things that I can't move on with until it's solved.....I'm glad to see that there are lots more just as "sick" as I am out there.....Muchas Gracias!!!!!
How did you encode the DivX to VCD in the first place ? if you used TMPGEnc, why didn't you use the Source Range ?
That way you'd encode the file in two parts and won't need to mess around with cutting it up later.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
used source range, but got only video and no audio...what am I missing?...Thanks
You may have to extract the audio as a WAV with Virtualdub them try converting in in TMPGE again using the WAV as the Audio source.
MPG files are too large
By sldvd in forum Video ConversionReplies: 2Last Post: 6th Mar 2011, 05:59 -
Copying Large Files
By persephone in forum ComputerReplies: 14Last Post: 13th Dec 2010, 03:23 -
video files are to large!!!!!!!!!!
By sharmine in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2008, 06:30 -
ImgTool Files Too Large
By opieandy in forum Authoring (DVD)Replies: 4Last Post: 27th Sep 2007, 21:08 -
Dr. DivX converts large VOB files into tiny unusable divX files
By texas1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 21:44
