  1. Member grannyGeek's Avatar
    Apr 2006
    Land of the Rising Sun
    Here is example of my process ---
    DvdShrink in Reauthor mode to cut 2 clips from dvd, with one audio track selected.
    (I have "enabled logical remapping".)
    PgcDemux to demux some clips for audio editing, edit the 2-ch 192 kbps ac3 track in Audacity 1.3.7 (just a simple fade out), export the track to ac3 format (g-spot shows same specs for edited track as for original demuxed track.)
    Remux with Muxman "free" version.
    Re-name all the vobs in sequential order.
    VobEdit to "Join Clips".
    IfoEdit to "Create Ifos".
    IfoEdit to Strip ("Vob Extras" process)
    Sometimes this works perfectly.
    Sometimes, I end up with two audio tracks, neither one having sound for the entire duration.
    Say I have clip A 3 minutes + clip B 2 minutes
    Track # 1 has 3 minutes silence, then sound.
    Track # 2 has 3 minutes sound, then silence.
    Why aren't the tracks merging?
    As I noted, sometimes it works perfectly, so I can't really blame Audacity (although I even tried editing and exporting to wav, and then convert that with BeLight -- still won't work.)
    Is this something like the audio CBR / VBR thing you hit with mp3 sometimes?
    Is the re-mux doing something to the video bit-rate that makes the two clips no longer compatible?
    Or (long screech of shrill violins....) is my computer possessed by an evil demon?
    grannyGeek ~~
    Antique Newbie
  2. Actually I don't know why the clips are 'incompatible' if the audio properties are the same. But they have to be EXACTLY the same: Bitrate, number of channels, bits per sample, encoding (stereo/joint stereo). AFAIK VBR is not supported at all, so this should not be the problem. Another idea:
    Why not join the clips as elementary streams with mpeg2schnitt or cuttermaran? Then you would avoid all 'past processing' steps (rename vob files, vobedit + ifoedit). And at least mpeg2schnitt can do a fade out effect by itself.
  3. Member grannyGeek's Avatar
    Apr 2006
    Hi, thanks so much for responding.
    I will give the "mpeg cut" tools a try tonight and see how I land.
    I was paranoid about trying anything like that, from stories about loss of audio sync.
    But I guess better to have to tweak sync than to have half-silent tracks.
    Thanks for the advice!
    grannyGeek ~~
    Antique Newbie
