For the life of me, I cannot seem to configure this after installing a Linksys N router. Arghhh!!
I know both my internal and external ip addresses, but just can't seem to tweak the program the right way.
Any suggestions?
-The Mang
you may have to do a port forward on the router, the ip for the router is 192.168.1.1
If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078 -
That would be the default address, not necessarily the one it is using now.
CMD prompt, ipconfig/all, the Gateway address is the one you want.
Agree with the above, the router is almost certainly blocking the port. Port forwarding or use the DMZ. -
the 192.168.1.1 ip is so you can access the router to see the config page for it so you can set up the router. open your browser and put in http://192.168.1.1 you may need to to make a user name and password before the page will load.
VPN and Static Routing with Linksys router
By CogoSWSDS in forum ComputerReplies: 0Last Post: 30th Aug 2009, 00:33 -
Free FTP client
By zoobie in forum ComputerReplies: 2Last Post: 1st Apr 2009, 03:49 -
How Can I Set-Up the Linksys Wireless Router??
By Frank-0-Video in forum ComputerReplies: 9Last Post: 27th Feb 2009, 16:18 -
Linksys WRT54GX4 router problem
By SIRCOOKS in forum ComputerReplies: 9Last Post: 19th Feb 2008, 11:40 -
Problwm with connecting to ftp using linksys router
By Wizard23 in forum ComputerReplies: 9Last Post: 3rd Nov 2007, 01:42
