I have a DVD probably from Portugal and I'm getting an error message like "prohibited by area limits".
Searching on google, I became even more confused. Some people say it's a problem with DVD region(mine is 4), while others say it's problem related to PAL. And that most players in North and South America can't play PAL DVDs. Is it true?
Well, anyway, I saw this post https://www.videohelp.com/forum/viewtopic.php?t=221928 downloaded IfoEdit and changed all the ifo files to NTSC. But when I reopen the same files in the program, I see PAL. What might be the cause?
Or: is there any other program? Oh and, I don't want to lose the menus.
Results 1 to 9 of 9
Philips dvd players are the best bet for pal on ntsc TV playing, converting is largely unnecessary
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
You can rip the DVD to your hard drive and re-burn it to a new disc, using single layer or dual layer DVDs as necessary with no conversion or compression at all. We have many guides on doing this. Since you live in Brazil, you live in a PAL country and I would think that ripping and re-burning the DVD is your easiest solution as ripping will remove the region code from the DVD.
Brazil TV uses PAL-M which is for 525/60 displays, so native DVD players must be NTSC.Originally Posted by jman98
The DVD players here don't accept PAL. Only NTSC, as far as I know. I have a Sony DVD player and reading the manual, it says it's a NTSC system.
Like this one? http://www.dvd-guides.com/content/view/225/59/Originally Posted by jman98
What about the menus?
Also, I followed this guide: https://forum.videohelp.com/topic338721.html but I didn't see any option to change PAL to NTSC. -
Here are a bunch of guides on converting PAL DVD to NTSC.
https://www.videohelp.com/guides?searchtext=&tools=&madeby=&formatconversionselect=&how...or+List+Guides
You could try this:
https://forum.videohelp.com/topic221928.html\
There are no promises it will work as some DVD players don't like this method, but it does often work and it's quick. -
I agree with victoriabears. Get Philips DVD player($30 CDN), they can be easily set to region free (all regions) and play PAL DVD on NTSC TV.
To convert DVD with menus is lots of work, it is much easier to get right player. -
Because it is VERY VERY DIFFICULT.Originally Posted by user2008
Start from the word DIFFICULT then rethink what you want to do. -
https://www.videohelp.com/guides/how-to-convert-interlaced-pal-dvd-to-ntsc-dvd-id1107#1107
I have about 50% of my collection is PAL and I would never spend the weeks needed to learn how to convert, get on with your life, buy the right dvd player.PAL/NTSC problem solver.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
How to convert NTSC to PAL?
By jebinio in forum Video ConversionReplies: 15Last Post: 8th May 2009, 20:03 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45 -
PAL to NTSC keep all menus
By Stankia in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 13:45 -
How can I convert PAL menus to NTSC
By alfo666 in forum Authoring (DVD)Replies: 2Last Post: 30th Jun 2007, 00:50
