I have Ulead Videostudio SE DVD authoring software, which came with a video capture device i bought. The video i recorded from my standalone DVD Recorder is only 4gigabytes in size. I then used Avidemux to change the audio from AC3 to WAV, and then edited the video a bit by taking out some commercials. Now, after saving it back to .mpeg using Avidemux, and now using Ulead Videostudio SE DVD, it's going to take about 4 hours to do the video/audio multiplexing. Right now, it's been a half-hour since i started, and it's only done about 8% of the multiplexing. Is there anything out there that is faster that someone could recommend?
That sounds horribly like it is re-encoding, which you really don't want to do.
For simple multiplexing, muxman should fit the bill. If you want a prettier face than just a command line, try GUIForDVDAuthor.Read my blog here.
GUI4DVDAuthor is a bitch for a newbie to negotiate, I wouldn't recommend that at all, and the manual is a convoluted mess.Originally Posted by guns1inger
DVDAuthorGUI is MUCH MUCH more user-friendly. DVD Styler also.
Muxman a command-line app??
Problem with Ulead Videostudio SE DVD and EasyCAP
By Majora in forum Capturing and VCRReplies: 17Last Post: 20th Nov 2011, 03:51 -
Author HD-DVD using x.264 Ulead VideoStudio 11 Plus???
By blkdumplin in forum Authoring (Blu-ray)Replies: 13Last Post: 18th Mar 2009, 08:48 -
Audio not working in Ulead VideoStudio 8.0 SE DVD
By darts44 in forum AudioReplies: 9Last Post: 23rd Jul 2008, 07:54 -
Ulead VideoStudio 10 + Dazzle DVD Recorder = No Sound???
By firebirdta84 in forum Capturing and VCRReplies: 1Last Post: 18th Jan 2008, 08:26 -
Truncation problem when burning DVD using Ulead VideoStudio 8
By goodneit in forum Authoring (DVD)Replies: 3Last Post: 9th Jun 2007, 10:23
