Apologies in advance if this question has been answered elsewhere -- I have scanned the forum and found bits and pieces, but I'm still not quite clear. So please bear with me.
I recently bought my first HD Camcorder (HV30) and made some movies in HDV of our vacation. I am now looking to make a DVD. I have a good PC, Pinnacle Studio 11 Plus, a regular (non-Bluray) DVD burner and a regular DVD player. Once I have edited my movie, I intend as a first step to save it back to a miniDV tape so i preserve the original HDV quality in case I upgrade to all-HD equipment later. But in the mean time, I would like to make the best quality DVD possible with my standard equipment. A few questions:
1. If I select Make Movie, Best Quality (720x480 at 8500kbs) with Dolby-2 as I found on another post, is that my best option? Will the results look any better than SD footage burnt to a regular DVD?
2. How long can the movie be in the above case?
3. Any alternatives to the above to produce better quality?
4. Is there any benefit from upgrading as follows:
(a) Buying a Bluray DVD player? Will I get better quality? Or do I need a Bluray burner to get better quality?
(b) Using Bluray DVDs?
5. I have heard there are problems with Menus in the above process. Is that true?
many thanks in advance.
Humility is a much under-rated human virtue
Yes.Originally Posted by lasereyes
Well, you're turning it into SD footage. But it will probably look better than if you had shot the video in SD to start with.Originally Posted by lasereyes
About an hour. Exactly how much depends on the audio bitrate.Originally Posted by lasereyes
Not for regular DVD players.Originally Posted by lasereyes
You can convert to AVCHD -- basically HD video on a DVD. That will give you HD resolution but limited running time and compression artifacts.Originally Posted by lasereyes
You can increase the running time and reduce artifacting.Originally Posted by lasereyes
You mean HD on DVD/Blu-ray? I don't have experience in this but I think the menu options are limited. Menus on SD DVDs will be no problem.Originally Posted by lasereyes
Date/Time Stamp for HDV Footage
By lasereyes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 26Last Post: 18th Mar 2019, 03:25 -
CS 5.5.2 fails to export HDV footage to tape/perplexed
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 19th Apr 2012, 22:41 -
Encoding downsized HDV 24p footage to MPEG-2 properly
By stantheman1976 in forum Video ConversionReplies: 41Last Post: 7th Dec 2010, 22:04 -
Have Canon HDV A1 footage to convert to SD
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 5Last Post: 1st Jul 2010, 13:13 -
Inclusion of DV footage into HDV format project
By adanchev in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2008, 02:34
