Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
  1. First off, can anyone tell me what formats will play in Qucktime? secondly, I've followed the instructions on how to format video into iPod friendly format. After the conversion, the video will play but, there's no sound. Lastly, can .wmv be converted to play on an iPod? Oh, by the way, I have an iPod classic 120G. If that makes any difference. Thanks for any help.
    Use ipodme.
  3. thanks Baldrick. One more question. What is .Net framework?
    Apr 2004
    Miskatonic U
    It is a series of libraries for the Windows Xp/Vista OSes that allow coders to quickly code programs without having to worry about all the interface elements and a lot of backend routines. It is an evolution of the old Visual Basic style runtime libraries that had to be copied with every program.
    Download and install the appropriate .net libraries from Microsoft.
    Read my blog here.
  5. Thanks Baldrick and Gunslinger. Folllowed your instructions and it works perfectly now.
