Very nice program.
Pity it's never been update since then. :C
---> http://abcavi.kibi.ru/
Thanks.abcAVI Tag Editor is little stand alone utility for viewing/editing tags in AVI files. In short it allows you to get information on movie from Internet Movie Database or type it by yourself and save that info inside AVI file. Supports RIFF INFO tags, MovieID tags, IDivX tags. Allows editing more than 40 tags, not only "Title", "Subject" and "Copyright". Support of RIFF INFO tags ensures backward compatibility with standard Windows players like MS Media Player.
abcAVI Tag Editor shows complete information on AVI file both in tree style and in short form. It recognizes more than 770 FourCC and TwoCC codes (shows complete names of audio/video codecs used). Has predefined lists of contents for some tags (Product, Genre, Rated, Language, Source form and Medium). Allows multiple file editing - supports Drag-and-Drop files and directories to the main window (for example from "Find files" window), embeds its item to the MS Explorer context menu.
abcAVI Tag Editor allows changing of FourCC video codec signatures, AVI frame rate (playback speed) and video frame size.
abcAVI Tag Editor has Import function - getting information from Internet Movie Database. You can choose what to import (around 30 positions) and set the corresponding limitations. abcAVI sends all queries through e-mail interface and economize your bandwidth (only useful information is getting from IMDb).
abcAVI Tag Editor has flexible report creating system (Export function). You can create your own export templates using more than 150 predefined keywords (technical information on AVI file, AVI tags, etc). abcAVI supports TXT, HTML, XLS formats and other textual formats at your choice. As an additional function export system can rename AVI files.
abcAVI Tag Editor comes with Info Tips Shell Extension. It means when you place mouse cursor over the AVI file name, the "yellow note" with all the technical and textual information popups.
devil (johner)
Results 1 to 1 of 1
MKV Tag Editor
By gonwk in forum Newbie / General discussionsReplies: 32Last Post: 24th Jan 2021, 09:39 -
How to edit MKV Tags? Is there any MKV Tag Editor available?
By Bonie81 in forum Video ConversionReplies: 1Last Post: 6th Nov 2011, 11:20 -
Pinnacle studio 14 tag editor or other software noob
By jamesleewhite in forum EditingReplies: 0Last Post: 23rd Jul 2010, 01:22 -
WMA tag editor / renamer
By olyteddy in forum AudioReplies: 5Last Post: 13th May 2009, 10:37 -
Is there a good tag editor like MetaX, except able to do AVI and MOV files?
By VidHunter in forum MacReplies: 0Last Post: 9th Nov 2007, 05:57
