Results 1 to 10 of 10
    Mar 2009
    Romania
    Hey guys
    I`m new registrated here and I have some qustions.First,I read many threads here but I am unable to find an tutorial to rip some DvDs...I want to save them on my PC/laptop and to be able to look at them in my traveling days(I travel a lot).So can anybody teach me how to rip them in Advanced FileSize Regulation (AFR) ? I`ve looked for tutorials everywhere and nothing...I want to reach this quality:
    Format                                AVI
    File size                              1.45 GiB
    Overall bit rate                    2 325 Kbps
    Video
    Format                                MPEG-4 Visual
    Format profile                      Streaming Video@L1
    Format settings, BVOP          Yes
    Format settings, QPel            No
    Format settings, GMC            No warppoints
    Format settings, Matrix          Custom
    Codec ID                             XVID
    Bit rate                               1 931 Kbps
    Width                                  720 pixels
    Height                                 388 pixels
    Display aspect ratio              1.856
    Frame rate                           23.976 fps
    Original frame rate               23.976 fps
    Resolution                            24 bits
    Colorimetry                          4:2:0
    Bits/(Pixel*Frame)                 0.276
    Audio
    Format                                  AC-3
    Format/Info                           Audio Coding 3
    Bit rate mode                        Constant
    Bit rate                                 384 Kbps
    Channel(s)                            6 channels
    Channel positions                   Front: L C R, Surround: L R, LFE
    Sampling rate                        48.0 KHz
    Ofcourse,some of those are impossible to get from some DvDs,like 6 channels(when audio is mono) but you get what I need to make.Thanks.
    PS: If we have an tutorial around here, please don`t be mad and post an link.
    Apr 2004
    Miskatonic U
    So basically you are asking us how to pirate movies ?
    Why else would you be asking how to encode to arbitrary filesizes used by pirate groups ?
    If you do a little searching on your own you find all the tools and tutorials you need to rip and encode DVDs for private use. However as a first post, this seems more than a little suspicious.
    Read my blog here.
  3. It's not from any "scene" group, as it would be immediately nuked for having too high of a resolution, having only a Mod4 height, for using a custom quantisation matrix, and for being oversized for a 2 CD rip. Based on the information supplied for that encode, I'm not sure it's anything I'd want to emulate, not that the "scene" standards are worth copying for our own day-to-day backups. My suggestion is to use AutoGK to encode until you know what you're doing.
    Does anyone know what "Advanced FileSize Regulation" is? 7abatrista?
    Edit: Never mind, I looked it up. It's a newer file size "standard" for pirates, just as guns1inger said.
    Mar 2009
    Romania
    Yes guns1inger,that I read myself.But I have to say it is not new...And this is something I ask for my own personal use,I don`t care about scene or pirates or whatever.Just want to have something to watch on my laptop and to be happy with quality...I used AutoGK and MediaConverter and the final rips were low quality,pixelised(I hope this is the definition).Bad shadows and uhm...sorry for giving wrong impression guys.If an mod think this thread is suspicious ,please delete it.,if not I will be very happy to try whatever you guys are recomending.Thanks.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If you want quality at low(er) file sizes, use Xvid4PSP and encode to H264 in an MKV container. Set Audio to Copy and you can keep your multi-channel audio. Use the X264 Q21 Ultra setting first and see how you feel about the size and the quality. Q18 will improve the quality, but increase the file size.
    Read my blog here.
    Mar 2009
    Romania
    Oh...you`ve lost me . Can you explain what you just write?I am newbie and don`t know what you talk about.Maybe you can make some screenshoots or something.Thanks for your kindness
    Apr 2004
    Miskatonic U
    If you install Xvid4PSP then most of it will become self-evident
    Read my blog here.
  8. Member MysticE's Avatar
    Nov 2003
    Well although guns1inger's suggestions are obviously sound, it may be overkill going by your statement:
    Seems just a basic Xvid should do fine for laptop viewing.
    Rip your DVD as a 'movie only'. Grab this little free app.
    http://forum.doom9.org/showthread.php?t=127298
    For 'open file' choose your VIDEO_TS.IFO. Bump up the audio quality to 160 (multi channel audio is not really needed on a laptop). Choose one of the last 2 Video Presets (the last one produces the largest file), leave everything else at default. The resulting AVI should look quite good on a laptop and better than any 'Scene Release'.
    Mar 2009
    Romania
    thanks
