I'm making a music video to a tv show. I want the music to play all the way through, and with clips. My problem is some of my video clips also have a sound clip with them, which I want to keep in.
When I play my video back, when it gets to one of these clips, all the sound, including the music, goes off. You have to pause it, wait a bit, then press play again for it to work, only for it to stop again when it gets to another clip.
How do i stop this?
Results 1 to 10 of 10
Hard to say without being there, but it sounds like your PC isn't powerful enough to handle previewing the audio.
You may have to render/mix it back to 2 track stereo and listen to that. -
how would i do that lol? Sorry, i just got it and im a lot confused
http://www.shockwave-sound.com/Articles/105_Working_With_Audio_in_Sony_Vegas_Part_2.html
Right side, halfway down -
I'm familiar with the problem. It might help if you turn off 'enable Media Manager (requires a restart) in your preferences tab. My computer is quite slow when i preview my video. I had to render my video a couple of times just to check my video effects and transitions.
Here are my computer specs:
Operating System: WinXP home edition
CPU Speed: XP1.66 GHz
Harddrive space: 120 gb
RAM Memory: 1024mb
Video Card:
Is my computer too slow for Sony Vegas Pro 8? And if so, what should/can i do about it? Get more RAM memory?
@guns1inger: What do you mean with other things going on in the background? I usually have a few internet sites (like news or forum sites) in the background running. Does this really affect the speed of previewing a video?
Thanks a lot!
Jules -
Are you using a separate hard drive for your video files? If you aren't, this will slow things down. External drives are cheap now and help alot for editing speed.
I have several files on an external harddrive and several on the computer harddrive. Are you saying i should make the video files i want to use to the external harddrive? I thought that would slow it down rather than help with editing speed...
Very educational. Thank you! I think i'll upgrade the RAM to 2GB anyway.
Btw, does it matter that i work with a laptop instead of a regular computer?
Sony Vegas Pro 10
By av.sorong in forum EditingReplies: 16Last Post: 9th Oct 2011, 13:27 -
Sony Vegas Pro
By Liquid9Kitty in forum EditingReplies: 2Last Post: 15th Feb 2009, 03:53 -
Sony Vegas 8 pro
By SNK in forum Video Streaming DownloadingReplies: 7Last Post: 20th Nov 2008, 09:09 -
Sony vegas 8 pro help
By jaycool1995 in forum EditingReplies: 2Last Post: 31st May 2008, 14:58 -
By jaycool1995 in forum EditingReplies: 5Last Post: 28th May 2008, 08:02
