I ripped a my copy of Tropic Thunder to my computer as an avi file. I want to edit some of the movie (language) and then re-burn it to a dvd. What programs can I use to edit the file without losing the quality. After editing the file, should I convert it to a different format to prevent image quality lose. I'm new to all this video file stuff.
Also, I'm on a new MacBook Pro.
You are going to need a decent NLE ( Non Linear Editor) Program,
as you will need to work with specific times / frame by frame
if you truly want to have a professional quality edit that doesn't
result in a bunch of herky jerky cuts that would mess up the narrative.
For that, iMovie 09, FCE or FCP will be your best bets,
as all three allow you to cut by the second/frame the few bits
of language you do not wish to hear.
All will require you to convert the ripped .VOB files to
DV Stream format to import into them for editing.
You can then export back out to iDVD to burn.
Now I have to ask the question.....After seeing the trailer in iTunes
(RED version), you pretty much KNOW the type of language used
in the film....Why buy it if adult language bothers you?"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
How to increase Video Sound Levels on AVI Files or wmv files
By lovebeing in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2010, 08:25 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 22:42 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 20:32 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
