Hi, i'm new here and I am experiencing a highly inconvenient problem
every time i try to open a Xvid file in VirtualDub it says:
Couldn't locate decompressor for format 'Xvid' (unknown)
VirtualDub requires a codec for Windows (VFW) compatible codec to decompress video.
Directshow codecs, such as those used by windows media player, are not suitable"
I know many people have asked this question but for them it works when they install an Binay Xvid codec like Koepi's
but when I do this, it just returns the error message described aboveso how the f*ck am I supposed to open a Xvid File in virtualdub?
please help since this is bothering me the whole weekend already -.-
thanks in advance!
Results 1 to 10 of 10
hi, thx for the swift reply ^^
Format : AVI
File size : 695 MiB
Duration : 1h 55mn
Overall bit rate : 845 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Video
Format : MPEG-4 Visual
Format profile : Streaming Video@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 55mn
Bit rate : 708 Kbps
Width : 656 pixels
Height : 272 pixels
Display aspect ratio : 2.412
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.166
Stream size : 583 MiB (84%)
Writing library : XviD 1.1.2 (UTC 2006-11-01)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 55mn
Bit rate mode : Variable
Bit rate : 124 Kbps
Nominal bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 102 MiB (15%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 148 ms
Writing library : LAME3.90.
Encoding settings : ABR
thats the info from media info.
i also downloaded avidemux but I don't know ho to use it!
so could you please help me some further?
thx! -
Xvid + Vista64? It requires a special installation:
https://forum.videohelp.com/topic332208.html#1723154
Even with Vista32 I think you have to install as Administrator. -
I can install xvid on my computer with no special permission and no problems at all,try a newer version of xvid.
i've tried the CMD stuff but I don't have a file with an .inf extension as in that tutorial... so how exactly should i install my Xvid using this method?
thanks!
PS. I have koepi's xvid V 1.2.1
Problem with opening AC3 in VirtualDub
By andy_blah in forum AudioReplies: 5Last Post: 6th Nov 2012, 17:25 -
Problem Opening h264 in VDubMod [MKV - XviD Conversion]
By catastrophe in forum Video ConversionReplies: 3Last Post: 1st Jul 2010, 19:13 -
VirtualDub, problem with *.ts opening
By UMO in forum Newbie / General discussionsReplies: 0Last Post: 27th Feb 2010, 16:50 -
Problem opening (.avs) file in virtualdub...
By dominator007 in forum DVD RippingReplies: 16Last Post: 19th Nov 2008, 11:53 -
Virtualdub Xvid Decompressor problem
By unkown in forum EditingReplies: 12Last Post: 13th Aug 2007, 20:38
