My second hard drive on my laptop was heating up and going offline.
So I decided to backup again and buy a new one.
Now I have removed most of the data off it, it seems to be coming good.
Any ideas on why this would be happening?
Is the laptop maybe not designed to run over a certain ?GB
cheers.
how fast the hard drive is spinning, how many platters it has, and how often it's being accessed would all be factors in determining the heat output of the drive...how well ventilated it is would determine how well the former issues can be handled.
Are you sure it's a heat problem? HDDs can run very hot and not have any problems. Usually in a laptop they have little or no ventilation. But if it's a big concern, you might consider a external HDD.
It was actually a connection problem
there was room for the HD to move back and cause a gap
thus overheating as the data had to jump so to speak across the gap
anyways, seems fine now
cheers -
Krispy
nice pic
shes a hot one
the guy who put the HD in did not do it properly
but a week later and still ok
cheers
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 15:58
