Hello,
I've got a problem with a mp4 movie wich i've recorded with my phone. After I've accidentily deleted it, I tried to recover it with an undelete program.. Wich worked perfectly in the past..
But now i can recover the file but can't view it.. (Also VLC & MPC didn't work)
Next to the movie files there where also other files recovered, files with no extension, with the same name as the video but with extra "_Vide" in the name.. Very small files about 4-5 kB's..
The movie files give the next sheet in MediaInfo & MediaCoder:
Strange thing is that the language is Japanese, If anything it should be Dutch or at least English I would think..Complete name : D:\TEMPP\DCIM\100MSDCF\_OV00869.MP4
Format : MPEG-4
Format profile : 3GPP Media Release 5
Codec ID : 3gp5
File size : 4.38 MiB
Duration : 1mn 49s
Overall bit rate : 336 Kbps
Encoded date : UTC 2009-01-10 13:32:34
Tagged date : UTC 2009-01-10 13:32:34
Format : 3GPP
Format/Info : 3GPP Media Release 5
Format/Family : MPEG-4
PlayTime : 1mn 49s
Bit rate : 336 Kbps
Video #0
Codec : MPEG-4 Visual
Codec profile : Simple Profile/Level 3
Codec settings/BVOP : Yes
Codec settings/QPel : No
Codec settings/GMC : 0
Codec settings/Matri : Default
PlayTime : 1mn 49s
Bit rate : 384 Kbps
Bit rate mode : VBR
Width : 320 pixels
Height : 240 pixels
Display Aspect ratio : 4/3
Frame rate : 23330144256.000 fps
Minimum frame rate : 0.000 fps
Maximum frame rate : 43.478 fps
Resolution : 8 bits
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.000
Language : Japanese
I did't overwrite the data on the phone, since I made the movie and deleted it, I didn't record any other video's, made pictures or write anything on the phonecard.. So the files should be undeleted corectly..
Before I deleted them, the files the played fine on the phone..
Does anybody has any idea? Or at least can help me find out what the problem is, by give me some hints with programs wich I can try?
I've tried a lot of programs but for example AtomicParsely, but since I've never worked with this kind of stuff I don't know what to do exactely..
One of the programs gave information about an missing or broken Moov Atom, but I don't know wich program it was, so I can't copy-paste the error...
Please, your help would be very much appreciated!
Sorry for any bad English, since Dutch is my mothertongue
Thanks in advance!
Results 1 to 9 of 9
When I use AtomicParsley with the -T function I get the following message:
But when I try "-t" the program gives this message:
Then AtomicParsley stops and is shutdown by xp.. (standard XP error message that the program has te be terminated with the standard question to tell Microsoft about is.. )
Anybody knows any other ways to find out what is wrong with the file, or better, knows how to repair it?
Thanks -
Still no luck
Maybe a mod could move this tread to the forum "Advanced Video Conversion" please??
I hope there are more people there who can help me...
Thanks in advance -
Marty
You might have "undeleted" the file. But I think you have a corrupted file with bad header. So it may be difficult to recover. -
But is there any way to find out what's wrong with the file then?
How to find out if it has a bad header, and is there any way to fix that / rewrite the header?
I'm kind of a noob in these things and are thankfull for any help -
I've noticed a very high framerate (Frame rate : 23330144256.000 fps ) ?!
Not very normal i guess.. But anybody knows a way to fix this? Or is this the result of another problem?
Are there maybe other sites that are specialized in this kind of problems? Maybe I can find my answers there? Honestly I don't know where to look anymore..
Thanx in advance! -
Isn't there anybody that knows how to lower the framerate, that's rediculously high?
Please?
Little kick..
Mp4 or 3gpp Files merge/joining and decoding parser
By fidogenial in forum Video ConversionReplies: 0Last Post: 8th Dec 2011, 14:02 -
mux 3gpp to mp4 with conconversions
By jntaylor63 in forum Video ConversionReplies: 1Last Post: 1st Oct 2010, 15:04 -
MP4 Won't Play on 360
By VDPD2005 in forum Video ConversionReplies: 6Last Post: 18th Aug 2010, 14:35 -
iPod Won't Play this MP4, but WHY?
By GrayStrickland in forum Video ConversionReplies: 3Last Post: 11th Jun 2009, 11:14 -
MP4 won't play
By lilblu in forum Software PlayingReplies: 3Last Post: 14th May 2009, 23:25
