Hi ....i desperately need someone to help me on how to extract frames from a video file. Thanks
Closed Thread
Depends on the file format, but Media Player Classic or Media Player Classic Home Cinema, among many others, can capture a frame with File->Save Image. Most video players have some sort of image save feature.
thanks for the reply manono, the video extension is .rec. i record it through a video conference software, then i need to extraxt frames of this video. Do you have a recomendation ? Thanks
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
Open the file in mediainfo (view=>text) post the information
You can renaming the extension manually to something like .mpg, or .avi
Thanks for the response poisondeathray, i've tried to use mediainfo to rename/export .rec file into .avi or .wav, however the windows media player can not recognize the video result. Would you please help me about it. i need to analyse the quality of this .rec video using a quality measurement tool, unfortunately, this tool doesn't work with .rec file. so i need to be able to play/edit this file and extract its frames to be analysed. thanks
PLEASE STOP make new topic about your .rec problem. Continue in https://forum.videohelp.com/topic364707.html
Extract frame from VOB file.
By kwazi in forum ProgrammingReplies: 8Last Post: 17th May 2013, 17:24 -
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 12:24 -
extract 1st frame of all new scenes
By lovelove in forum EditingReplies: 0Last Post: 6th Aug 2011, 09:57 -
How to extract I-Frame from Mpeg-4?
By ahrouhi in forum ProgrammingReplies: 7Last Post: 23rd Jan 2011, 18:56 -
Extract a frame from .flv file using .Net program
By evolvingwheel in forum EditingReplies: 0Last Post: 18th Jan 2009, 09:10
