For some reason all the bluray dvds I play on my pc play at the slow 25 fps framerate, so I can clearly see the separate frames, which is a bit annoying.
What do I need to do to make it play at 50 or 60 fps, like they do on the display TVs at best buy?
I have a new 2.5ghz dual core processor , 4gb ram and a decent video card. Is that enough computer power?
thanks
Most movies are native 24p. Your player or TV (depending on settings) will play 24p with 2x frame repeats (50Hz) or 4x frame interpolation or repeats to 100Hz.Originally Posted by Obamargarine
Computer playback depends on your software player or display card. LCD computer monitors usually refresh @60Hz. In the simplest 24p playback mode the display card will non-sync sample at 60Hz.. This may result in an uneven frame repeat of 2 or 3 samples per film frame.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
Blu ray player (Phillips BDP2700/12) won't play some movies.
By lema1610 in forum Authoring (Blu-ray)Replies: 8Last Post: 12th Oct 2011, 07:48 -
Can all blu-ray drives play/write 3D movies or just the '3D Capable' ones ?
By ahmadka in forum DVD & Blu-ray WritersReplies: 3Last Post: 28th Jun 2011, 11:37 -
Play full blu-ray movies on ps-3 from hard drive
By jim49 in forum Software PlayingReplies: 2Last Post: 7th Apr 2010, 18:54 -
Blu-ray or rip movies don't play in 5.1 surround sound. Help?
By Obamargarine in forum Software PlayingReplies: 1Last Post: 15th Feb 2009, 16:07
