Hi, I want to cut out part from a rmvb,
I can use rmeditor to do that for some rmvb files,
but for some other rmvb files, rmeditor return
"Error: The input file contains an unsupported codec. This file can not be edited."
example unsupported codec get from media player classic:
Audio: AAC 44100Hz stereo
Video: RealVideo 4 704x396 25.00fps 776Kbps
(1) Can I fix the problem by install new codec ?
(2) I get the rmeditor long time ago, I don't know its version because it don't show it. Is there some new version of rmeditor can do the job ?
(3) Is there any other simple software can do the job ? I don't want re-encode, convert-format, etc.
Thanks for help in advance.
easy real media editor 1.73 (free)
Sometimes, when your file is damaged, it will be difficult to edit. - you often have to cut out the bad segements then append them. I suspect that the files you are having problems with are damaged. -
Thanks for help. I will try that software.
I think the problem don't come from "damaged file", the files come from different sources and they all can play back normally. -
I'm adding a tool link to easy realmedia editor (it is included in easy realmedia producer).
Unsupported codec (id=86021) for input stream #0.1
By noctrine in forum ffmpegX general discussionReplies: 3Last Post: 9th Feb 2012, 09:13 -
FFMPEG Unsupported codec (id=86018) [i.e. AAC]
By kdigit in forum Video ConversionReplies: 10Last Post: 1st Mar 2011, 10:01 -
Unsupported codec (id = 0) in ffmpeg
By Nightslk in forum Video ConversionReplies: 3Last Post: 10th Nov 2009, 17:17 -
Unsupported FLV codec or format
By lovyagin in forum EditingReplies: 25Last Post: 11th Dec 2008, 23:13 -
which software can edit(cut&joint)rmvb?
By ptr866 in forum EditingReplies: 5Last Post: 1st Jun 2008, 11:56
