I connected my PC to my 52'' LCD TV (Sharp "LC52D65E") . My tv has a full HD resolution (1920×1080).
My graphic card is ASUS EAH4650 (ATI Radeon HD 4650 GPU)
ASUS says "Dual-link DVI Support: Able to drive the industry’s largest and highest resolution flat-panel displays up to 2560x1600".
I use a DVI-I to HDMI cable to connect my PC to my LCD TV.
I used Catalyst Control Center and made my TV as the secondary display device or monitor and everything went very smooth.
I can see that the tv says it received a 1080p 60 Hz signal in its HDMI input and it shows my pc desktop in the tv.
BUT
The picture is not full screen in my tv.
I have margins on all the sides.
It looks like that the resolution is much less than what is shows.
I thought the full resolution must show my pc desktop fit exactly in my tv without wasting any pixel.
Is there any way to fix this ?.
	What resolution do you have in Windows display settings? Have you tried changing the TV's display size (also called picture size or zoom)?
	Make sure your graphics card isn't set up for overscan compensation on the HDTV output.
 Most HDTVs overscan the input signal so the edges of the frame are cut off. Graphics cards can be set up to compensate for this by shrinking the desktop then padding with black borders. The overscan compensation on the HDTV then cuts off the black borders rather than the edges of the desktop. But all that scaling leaves you with a blurry picture.
	You have to manually adjust the video size since the hdtv wont auto adjust for size,it should be in the setup of the catalyst controls. I think,therefore i am a hamster.
	Thank you Very Much
 Now it works 1080p !!!
 This was the over scan compensation
  LCD image different using DVI and HDMIBy sohaibrazzaq in forum ComputerReplies: 17Last Post: 7th Jun 2011, 16:12
  Default Connecting laptop to HDTV - wanting best quality HDMI to DVI connBy mr-scarface in forum DVB / IPTVReplies: 8Last Post: 24th Aug 2008, 14:59
  Connecting PC to Samsung 40" LCD with DVI --> HDMI CableBy batorideikou in forum ComputerReplies: 7Last Post: 9th May 2008, 11:45
  Problem connecting computer (DVI) to TV (HDMI)By kizzad in forum DVB / IPTVReplies: 2Last Post: 14th Jan 2008, 21:52
  RESOLVED: Weird colour shift when connecting LCD tv to comp via DVIBy bigshotceo in forum DVB / IPTVReplies: 10Last Post: 22nd Dec 2007, 16:14
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
