Poll: Do bulky power adapters bother you?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 15 of 15
  1. Member yoda313's Avatar
    Jun 2004
    The Animus
    So do you ever get annoyed when you have those large power adapters for your electronics or other gadgets?
    I mean the ones I don't like are the ones that are long and rectangular. At least the square ones like the old NES and SNES power adapters could fit snugly on the end of a power strip and not take up too much room. But some of these more modern ones are at odd angles and are hard to find room for on strips.
    What about you? Any pet peeves on power plugs?
  2. Member Number Six's Avatar
    Mar 2008
    I like the small brick power supplies that have a separate wire that connects it to the power strip with a normal size plug. I hate the ones that have the plug built into the brick. I also try to replace all my class 2 transformer type power supplies with the newer style switching power supplies because the output is much cleaner and more stable.
    RE: "Uh-oh Yoda's off the medication again! (I'll ban anyone who chooses this!!!)"
    Yoda is NOT off his medication, but he IS taking alternate medication at improper doses :P
    "I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
    (NO MAN IS JUST A NUMBER)
    be seeing you ( RIP Patrick McGoohan )
    Aug 2006
    I view all wall-warts as a very annoying and unfortunately necessary evil.
  4. I do not let it bother me. I kind of like the squid idea.
    Believing yourself to be secure only takes one cracker to dispel your belief.
  5. Don't even think about it. Just plug it into the squid...
    http://www.cyberguys.com/templates/SearchDetail.asp?productID=18300
    Buy My Books
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    I think I know what you mean. The xbox 360 and its hd-dvd drive have a step down (if you can call it that) external power supply. From that you have a normal pronged plug (normal for your region of the world I imagine - US in my case so its two prong). That is nice except sometimes its a little difficult concealing the extra power strip. But at least it makes finding a spot on a power strip easier since its a normal smallish size.
  7. Member Number Six's Avatar
    Mar 2008
    Something like this:
    This is usually a switching power supply, but they can also be regulated DC power supplies.
  8. Member yoda313's Avatar
    Jun 2004
    The Animus
    @numbersix - yes that is exactly what I was talking about in reference to your description. The xbox 360 has a monster of one for the main console. The hd-dvd add on drive has one that is about that size. The coiled plug that is in that picture goes into the electronic device and than a normal plug to the wall goes in the other end of that block.
  9. Member Number Six's Avatar
    Mar 2008
    The xbox 360 power supply is a huge monster because it is 200w.
  10. Member Epicurus8a's Avatar
    Ocean West, USA (ATSC)
    Yes - I'd love it if they could all be normal sized plugs
    Big power supplies are unsightly.
    Dealing with a two or more can sometimes be challenging.
  11. Member yoda313's Avatar
    Jun 2004
    The Animus
    The thing I hate also is when you don't have a LONG enough cord as well.
    You always need just another inch or two to make it.....
    Jan 2004
    GEORGIA US
    I can't win!
    The transformer on the end of the cord will either block the next rececptical or force me to turn one upside down in a standard duplex which usually causes the transformer to just barely catch and often fall out at the worst moment. My cell charger is another type of brick on the end of the wire and it has the folding prongs for travel. What a POS! It barely catches without any compitition from other transformers.
    My laptop cord has the brick in the middle of the cord but the half of the cord that goes to the laptop keeps coming unpluged from the transformer with the slightest movement, same as my camcorder
    And don't even get me started on a couple of different car cigarette adaptors!
    Electricity is evil!
    IS IT SUPPOSED TO SMOKE LIKE THAT?
  13. Member yoda313's Avatar
    Jun 2004
    The Animus
    @zapper - yeah those ones that fold are annoying also. The DS adpater is like that - with the swivel out plug. Luckily it seems to snap in pretty firm.
    Jan 2004
    GEORGIA US
    yeah, the kids DS adaptor seems solid but we always plug it into a power strip so it doesn't have to hang from the wall
    on a side note I just heard on the radio that they are pushing for a cell phone charger "Standard" the mini USB
  15. Originally Posted by ZAPPER
    Isn't that the one almost all motorolas use now?. I had a V3 and a Pebble and they both used it.
    I think It's REALLY useful to be able to charge your cell phone from your pc, I just plugged the usb cable to the pc and voila!.
    1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!!
